Opinion about hardware
Discussion in '3CX Phone System - General' started by Borsoock, Jun 11, 2007.
  1. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Couple days ago I've bought T-com TC300 dual GSM/VoIP phone for affordable price. After some tests I'd like to share my opinion about this handy with you. It's basically same hardware as Pirelli DP-L10 (http://www.pirellibroadband.com/en_IT/browser/attachments/pdf/DPL10.pdf) phone but in different envelope so I've changed firmware to non T-com branded one form Pirelli.
    Most important (to me) points:
    - This phone can use WPA and WPA2 for WiFi without any problems (which is not so obvious for other equipment I've tested even if it was suppose to support this encryption methods).
    - It has STUN support.
    - G711a, G711u, G729 codec support
    - Last but not least :): It works perfectly with 3CX and it's stable!
    After comparison with very lousy Nokia E65 SIP client I'm very positively surprised by this little handy.
    But there is a trade-off - you will not find any fancy gadgets (except photo camera) in this phone, major minus is absence of bluetooth support and short battery life if phone is logged into both GSM and WiFi networks.
    So, if you are looking for relatively cheap and simple dual mode phone, you should definitely put this one on your list!
    Marcin
    [​IMG]
    [​IMG]
  2. Anonymous
    Anonymous Guest
    Very nice very nice indeed.
    << running off to find it on Ebay >>
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    223
    This is very good to know, thanks!
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Nice.....How much?
  5. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Equivalent of ~200 USD in my case.
    Marcin
  6. Anonymous
    Anonymous Guest
    Well here is another one, not tested yet but all the consultants in my company will get one next month.
    http://h10010.www1.hp.com/wwpc/au/en/ho/WF25a/1090709-1113753-1113753-1113753-1117925-12573438.html
    Will do Integrated quad band GSM/GPRS/EDGE, WLAN 802.11b, Bluetooth
  7. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Yes! Totally agree! I was searching for stable SIP client for Windows Mobile 5 recently and I couldn't really find anything reasonable.
    Marcin
