Option 9 Repeat Options
Discussion in 'CRM / Helpdesk / App Integration' started by claxtro, Oct 11, 2011.
  1. claxtro
    Mar 12, 2011
    22
    Newby Question but here it goes.
    When option 9 is selected it repeats the initialprompt of a menu component. I know about menu options but am lost how to do this in VAD. Thanks.
    --Rob.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Just leave option 9 as an invalid option, when the user presses it, the application will repeat the prompt.
    Not sure if this is what you need, otherwise explain in more detail and I'll give you my suggestion.
  3. claxtro
    Mar 12, 2011
    22
    Thanks and yes I did find that as well. But when the message repeats it nulls any user input for option selection during or after the repeat. Please advise.
  4. VAD_Support
    Aug 6, 2009
    690
    when an invalid option is detected, the buffer is cleared. But if you enter a valid option after that, it will be kept into the output property of the component.
    Are you experiencing a different result? In that case please send me the project you're creating so we can check if there is something wrong...
    Thanks,
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Have you just tried using a loop component? You can have option 9 repeat the prompt and save the variables.
