- Joined
- Mar 2, 2011
- Messages
- 5
- Reaction score
- 0
I purchased Bria for the iPhone, but am having a bit of trouble with it, so I decided to try 3CX since it was free. So far, I think it is really good although I keep getting messages that I lost registration with the server, but that is not my issue.
My issue is that with Bria, you have the option to either run the app in the background, which consumes a lot more power or not run it in the background, which saves a lot more power. The reason you would want to run the app in the background is if you are using UDP as the sip transport and you want to be able to receive inbound calls when the app is not in the foreground. This is not necessary if you are using TCP as the sip transport.
I would like to use 3CX, but am concerned about battery life so will only do so if it does not run in the background, but can still receive incoming calls through TCP transport.
I see the option in 3CX to turn TCP transport on or off. But what I don't know is if that setting also dictates whether the app runs in the background or not. I don't even know if 3CX has the option to either run in the background or not.
Any clarification of the issue would be greatly appreciated.
Device Info
Phone Model: iPhone
Generation: 5
Firmware Version: 6.1
Jailbreak: YES
Cydia Installed: YES
Device Info
Phone Model: iPhone
Generation: 5
Jailbreak: YES
