Option in 3cx software to change the BLF button numbering scheme
Discussion in 'Ideas' started by Brian Cross, Aug 7, 2017.
Option in 3cx software to change the BLF button numbering scheme 5 5 1votes
5/5, 1 vote
Tags:
  1. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    Depending on the hard phone you are using the buttons may be numbered per column downward. Example: 1-12 then the next column is 13-24. How the 3cx BLF buttons are currently numbered is top downward.
    This doesn't give you a 1to1 BLF layout. It would be a lot cleaner if you could layout the 3cx BLF keys just like the layout is on the hard phone. Easier for end users that switch from software to phone.
