Option keys don't work
Discussion in '3CX Phone System - General' started by shades, May 8, 2008.
  1. shades
    May 7, 2008
    11
    Hello to all,
    I am actually having two problems at the moment. I have activated digital reception, I recorded the message and can receive incoming calls with no problem, However when the call comes in the receptionist activates, but when you press the number of the extension nothing happens and then the system hangs up. anyone know what I might be doing wrong.
    2nd problem is when I hit version and updates I get this error:
    Cannot find server. Aquiring data failed. Please try again later.
    Product 3CXPSENTNFR
    Version Number 5
    Here is the log for the incoming call:
    08:15:45.558 Call::Terminate [CM503008]: Call(6): Call is terminated
    08:15:45.527 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:802
    08:15:45.199 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:802
    08:15:45.167 Call::Terminate [CM503008]: Call(6): Call is terminated
    08:15:45.167 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:802
    08:15:07.543 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:802
    08:15:07.496 CallCtrl::eek:nLegConnected [CM503007]: Call(6): Device joined: sip:208.239.76.169:5060;transport=udp;wlsscid=1ae4691c270666;appsessionid=app-6t3204jpa116
    08:15:07.340 CallCtrl::eek:nLegConnected [CM503007]: Call(6): Device joined: sip:
    08:15:07.309 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(6): Calling: IVR:802@[Dev]
    08:15:07.293 Line::printEndpointInfo [CM505003]: Provider:[varphonex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.5.25:5060]
    08:15:07.293 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:802
    08:15:07.152 CallCtrl::eek:nIncomingCall [CM503001]: Call(6): Incoming call from 5612484044@(Ln.10000@varphonex) to [sip:802@deathstar.skylinktek.com:5060]
    Thanks for any help you guys can give.
