Option to bypass called from and time
Discussion in '3CX Phone System - General' started by tjabaut, Jan 15, 2008.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    Is there anyway on the VM to bypass whom called and when. Some users want this sometimes, an others want to be able to hit the # key and bypass it.
    So if the VM starts with call at 4:12pm from 10801 the user could simply hit # (or another key) and bypass the time and caller number.
