Option to Disable 'Enter Key' to Answer
Discussion in 'Ideas' started by pact, Mar 6, 2017.
Option to Disable 'Enter Key' to Answer 5 5 17votes
5/5, 17 votes
  1. pact
    pact New Member
    Dec 16, 2009
    172
    31
    Can we please have an option to disable 'Enter Key to Answer'
    We have many clients who wish to have the SoftPhone pop up on call, but having it answer with the 'enter' key causes much confusion when clients are typing in a document and accidentally answer the call.
    And is there the possibility the Focus option could be turned into a 'Show Window on Top' mode, rather than stealing focus, as again the end user then stops typing into their document when the phone rings, which when they are in a large ring group becomes frustrating for them.
    DamianCorr likes this.
  2. Gary Taylor
    May 27, 2017
    We have the same issue in our company, is there a solution for this.
  3. Ben Lunt
    Jun 6, 2017
    I agree with the ability to change the key that allows you to answer the call when the window takes focus??
  4. ConnectworksNL
    Mar 2, 2017
    50
    12
  5. MathiasSF
    Jul 7, 2017
    9
    I would like to also request a feature that disables keyboard input to calls, as I have a few end users that end up answering or hanging up calls accidentally while typing.
    Thank you,
  6. AndreyP
    Apr 11, 2017
    40
    7
    Reported the same issue a while ago, so +1
  7. Silly English Kniggit
    Sep 13, 2017
    215
    77
    Same issue here. Lack of this makes popup of little use.
  8. Silly English Kniggit
    Sep 13, 2017
    215
    77
    Ability to set (inc by the XML file) a global hotkey (CTRL-ALT-A etc) that works regardless of if softphone has focus would be very useful addition. This would reduce need for focus stealing.
  9. ConnectworksNL
    Mar 2, 2017
    50
    12
    Come on 3CX any update in this, its so easy to implate but no reaction from your side.
  10. dcourtney
    Nov 30, 2016
    21
    +1, getting some disgruntled help desk workers on this one.
  11. Trevor Gordon
    Feb 13, 2018
    11
