Option to disable Feature key sync - Yealink phones
Discussion in 'Ideas' started by ppickens, Nov 30, 2017.
Option to disable Feature key sync - Yealink phones 5 5 4votes
5/5, 4 votes
  1. ppickens
    Jun 19, 2013
    27
    12
    Many clients prefer to set call forwarding via the phone itself, unfortunately the feature key sync option breaks this feature. Could we get an option to turn this off via the default template options?
    curtcar21 likes this.
  2. npereira
    Jan 5, 2009
    22
    I second that cause this forward from phone broke after upgrade to V15. If you dont support custom templates, then put the option in the provisioning page.
