Option to disable message deposit for 3CX extensions
Discussion in 'Ideas' started by etb, Sep 6, 2016.
  1. etb
    etb
    Jul 23, 2014
    The IVR is not working out for a medical practices. The need to change their voicemail quickly and without having the option to leave a message for certain announcements.
    We could use the extension voicemail for this, but withou the ability to leave a message.
    An option to disable message deposit per extension will do the trick.
    Regards, Jurgen Weijer
