Options IVR menu
Discussion in 'Ideas' started by Ronald Klijsen, Nov 21, 2017.
Options IVR menu 5 5 1votes
5/5, 1 vote
  1. Ronald Klijsen
    Nov 21, 2017
    When using an IVR, I can't do the following:
    connect to an extern number (outside number)
    connect to an non-user voicemail
    Would be nice to have those (basic) options...
  2. DL_
    DL_
    Mar 31, 2015
    55
    8
    Have you tried using the Call Flow Designer?
  3. Ronald Klijsen
    Nov 21, 2017
    Can I use the CFD with a standard license..?
  4. DL_
    DL_
    Mar 31, 2015
    55
    8
    No, you need pro or enterprise.
  5. Ronald Klijsen
    Nov 21, 2017
    so, how to fix this with a standard license :)
  6. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    862
    130
    connect to an extern number (outside number) - Create a dummy extension, and forward all calls to external number (using forwarding rules), within the IVR connect to this dummy extension.
    connect to an non-user voicemail - if the voicemail is on 3CX, again create a dummy extension and forward all calls to the correct voicemail
    Note ; you can hide the dummy extensions from the address book
