Orbtalk driving me mad
Discussion in '3CX Phone System - General' started by chemist458, Jan 18, 2008.
  1. chemist458
    Jan 17, 2008
    Dear All,
    I have registered all my other lines with sipgate no problem, but orbtalk says its registered but when I phone the number is says im not online.
    So 3cx version 5 says registered, orbtalk doesnt.
    The registrar for orbtalk is orbtalk.co.uk and the outbound proxy is nat.orbtalk.co.uk:5065, if I change any settings away from this it wont register, so it seems all the details are correct yet, I'm not online.
    Any ideas,
    Thanks in advance,
    George
  2. chemist458
    Jan 17, 2008
    Dear All,
    I have sorted it, just in case people need to know, I got rid off the stun server address on the config of the voip provider.
    Works fine now
    George
