Original called ID over the second sip trunk
Discussion in '3CX Phone System - General' started by mixig, Dec 16, 2013.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    is it possible to do this:
    I have 2 sip trunks, one si connected to my local telco and the another one is connected to some other pbx (VPN). What i am trying to accomplish is when outside person is callin DID number which is on DID i do "forward to outside number" -> e.g. 750 -> for that number i have an outbound rule whcih says send that to sip trunk 2 (other pbx). That part is working but i am sending new number in "from" field (main number from sip trunk one)-> I know this is right but i am interesting can i somehow keep the original number and send it to sip trunk 2?
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Easiest way is to setup "some other" PBX not as a peer but register it against a 3CX extension credentials. This passes the caller ID fine. No Bridge/trunk.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    I have solved this on my network with 30cx , 2 cucm , 3 wildix system
    Outbound setting on from user part = originator caller id number will be set
