Out of hours message
Discussion in '3CX Phone System - General' started by adamwells, Sep 16, 2015.
  1. adamwells
    Mar 20, 2015
    25
    How do I go about uploading a file we want to play when someone calls in, out side of office hours? And how would we enable this each night/disable each morning?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    132
    Need to configure office hrs,
    Settings -> General -> configure Office Hrs
    When you have done the above, you need to configure the incoming gateways to use Office Hrs, by deselecting 'Apply the same routing logic Outside of office hrs' and selecting the required route.
    You can do the same for an extension, by Edit Extension -> Office Hrs Scheduling - setup the office hrs and remember to tick 'Automatically change extension profile based on time of day'. Then configure the 'Do not Disturb' to route to the correct vm extension. When office is closed, extension will automatically go to 'Do not Disturb' and back to 'Available' when office is open
    You can change the system manually from in / out of office by dialing the system code. For the code check - Settings -. Advanced -> Dial Code
  3. adamwells
    Mar 20, 2015
    25
    Thank you. This is working just how I want.
