Out of LAN Connection
Discussion in '3CX Phone System - General' started by alonchu, Jul 29, 2008.
  1. alonchu
    Jul 18, 2008
    21
    Hi everyone,
    I am using my E65 as an SIP user on 3CX, and I am successful in using it inside the WiFi.
    I would like to able to connect to the 3CX through 3G portal, when I am out of the office.
    Has anyone done this?
    I am using a Cisco Router with a static in the Office and the 3CX has a dedicated internal IP.
    Can anyone tell me how this can be done?
    Many Thanks,
    Alon
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    I'm using E61 I cannot connect out of lan
    I tried vpn router and dmz
    I think it's something in 3cx
    because I can connect to other software and to sipphone
