Out of Office Phone
Discussion in 'Windows' started by jsmoli, Apr 5, 2011.
  1. jsmoli
    Apr 5, 2011
    i have a my server at my office and i am trying to set up another external computer at home, everything is the same software, and i am quite confused on what to do, i have just simply put the same information into the external as the internal.
  2. jsmoli
    Apr 5, 2011
    sorry, i will be more specific, i am trying to set up a out of office voip phone i have 4 others set up in office and i moved this computer from the office and into my home, this computer was working while at the office tho
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,477
    67
    You provided too few information to be helpful. However, I will try:
    You are working at COMPANY and your company has a PBX.
    Now, if you are at work, your network admin will tell you that the PBX has internal (intranet, private or in-office) address 10.0.0.1. In this case, you will set your 3CXPhone as being "In Office" to 10.0.0.1.
    If you want to connect your company PBX from home, your company's network admin will tell you that the PBX has external (internet, public or out-of-the-office) address PBX.COMPANY.COM or 232.232.232.232. In this case, you will set your 3CXPhone as being "Out of the Office" to PBX.COMPANY.COM or 232.232.232.232.
    The easiest test to check from home if the company PBX is reachable is to try in a command prompt
    telnet pbx.company.com 5060
    or
    telnet 232.232.232.232 5060
    Hope it helps.
    vali
  4. jsmoli
    Apr 5, 2011
    so than with that being said, as i am the company manager, i would use my out of office ip?
  5. Vali_3CX
    Dec 12, 2008
    1,477
    67
    Yes. You should know how your PBX is "seen" from "outside". As I said
    the easiest test to check from home if the company PBX is reachable is to try in a command prompt
    or
    Regards
    vali
