Solved Outbond Rule for manual selection outgoing trunk ?
Discussion in '3CX Phone System - General' started by itgs, Nov 14, 2017.
  1. itgs
    Nov 8, 2008
    57
    Could you help me to understand how can configure an outbound rule to permit manual selection of a specific outgoing trunk, adding a code prefix to number, from a specific group of extensions ?
    I tried to add *001 before the number , and configure the rule removing first 4 digits, but 3cx notify that the code is not valid.
    I tried other code with *XX but don't work.
    Thank you for help
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You can use codes like *8x for manual selection in outbound rules (omitting 3 digits), but you can't use these prefixes in forwarding or DID rules (they do not accept codes starting with * in version 15/15.5, must start with digit 0-9).
  3. itgs
    Nov 8, 2008
    57
    Thank you for your reply.
    I tried to use *81 , like you suggested, but 3CX reply with following audio message : "Progam code incorrect".
    My 3CX is V15.5
    Thank you
  4. sip.bg
    Nov 7, 2016
    704
    219
    This is strange, where are you getting this audio message -- probably your voip provider is playing it. It's not the 3CX PBX.
    You must delete 3 digits, i.e. the '*81' from the number dialed, e.g. *810123456789 and to pass only 0123456789 to the provider.
    Try using prefix like '98' instead and delete 2 digits, dial 980123456789.
  5. leejor
    10,757
    286
    Do you already use "9" as an outside prefix? If so, then keep it simple, use an "8", or a "7" (unless there is a conflict with extension numbering), to route out via a second or third trunk group.
  6. itgs
    Nov 8, 2008
    57
    Finally I discover the reason of my issue !!
    There was an outbound rule, using an extensions Group including the extension I'm using for test, that was placed before the rule I created.
    I did not noticed it.
    Thank you to everybody for support and sorry for mistake.
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Glad to hear the issue is resolved and thank you for sharing your solution
