Outboud Rules
Discussion in '3CX Phone System - General' started by 3cx-user, Nov 13, 2008.
  1. 3cx-user
    Aug 15, 2008
    14
    Ok this is my current setup.... Patton 4114 (4 Port) with only one line active on it so far for testing... I have the 3 other ports disabled for inbout/outbound but when I set the Patton to higher priority that my Voip line I would image that it would figure out that the only port available on the Patton is already used and then go the VOIP line for the 2nd outbound line but it does not appear to ever hit the VOIP line... this is the message in my logs so it does appear to know that it can't use the Patton...
    [CM303003]: There are no available outbound lines on gateway SN4114_01 at this time.
