- Joined
- Aug 5, 2013
- Messages
- 5
- Reaction score
- 0
I am having a strange delay issue the latest 3cx.
network setup
Firewall Pfsense
Internal network 192.168.201.0 /24
ip of pbx 192.168.201.10
all phones (cisco spa525g) on the internal network are seeing a 5 to a 10 second delay on any calls being made.. both to internal extensions and external numbers
however
remote phones and the 3cx Client see no delay and are instantaneous
this includes cisco spa525 phones that are connected via vpn. absolutely no delay
however every phone on the same subnet as the phone are seeing this delay . I've set up nat reflection, split dns, and nothing seems to help.
nothing noticeable in the activity logs. except that Default IP is configured (SIPINTERFACEIP
is logged about 3 - 4 seconds after call is initiated.
network setup
Firewall Pfsense
however
Code:
02/08/2018 2:26:58 PM - Default IP is configured (SIPINTERFACEIP) as 192.168.201.10
02/08/2018 2:26:57 PM - Updating device Dev(171539975):[sip:[email protected]:5488;rinstance=29f868914ca3b986 / DialCode] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5488 tid=e34c3d70ca14ad51 Call-ID=M9ofQMelTs9JAI9BzpklHQ..:
REGISTER sip:pbx.fqdn.removed SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-524287-1---e34c3d70ca14ad51;rport=5488
Max-Forwards: 70
Contact: <sip:[email protected]:5488;rinstance=29f868914ca3b986>
To: <sip:[email protected]>
Call-ID: M9ofQMelTs9JAI9BzpklHQ..
CSeq: 111 REGISTER
Expires: 120
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="DialCode",realm="3CXPhoneSystem",nonce="414d535c108d157146:23e50400278471d889efdd7bb732100e",uri="sip:pbx.fqdn.removed",response="26e9771479370edb51598607463221b7",algorithm=MD5
Supported: replaces
User-Agent: 3CX DialCode Processor
Content-Length: 0
02/08/2018 2:26:50 PM - Updating device Dev(1695437124):[sip:[email protected]:5060 / 901] by message: DevUpd Recv Req REGISTER from 192.168.65.103:5060 tid=-b870e16f [email protected]:
REGISTER sip:192.168.201.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.65.103:5060;branch=z9hG4bK-b870e16f
Max-Forwards: 70
Contact: "Test Phone" <sip:[email protected]:5060>;expires=120
To: "Test Phone" <sip:[email protected]>
From: "Test Phone"<sip:[email protected]>;tag=e1050ce0df888db0o0
Call-ID: [email protected]
CSeq: 64202 REGISTER
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
Proxy-Authorization: Digest username="2ckl74a",realm="3CXPhoneSystem",nonce="414d535c108d438a81:f9fa72a3ab9919675ad4283c49b7e98b",uri="sip:192.168.201.10:5060",algorithm=MD5,response="9cca1ff433a97ae115ae814764366946"
Supported: replaces
User-Agent: Cisco/SPA525G2-7.6.1
Content-Length: 0
02/08/2018 2:26:49 PM - Updating device Dev(720403273):[sip:[email protected]:5060 / 208] by message: DevUpd Recv Req REGISTER from 192.168.201.112:5060 tid=-66be00d8 [email protected]:
Via: SIP/2.0/UDP 192.168.201.112:5060;branch=z9hG4bK-66be00d8
Max-Forwards: 70
Contact: "Sonya Talley" <sip:[email protected]:5060>;expires=120
To: "Sonya Talley" <sip:[email protected]>
From: "Sonya Talley"<sip:[email protected]>;tag=93f9f8b3b40ee529o0
CSeq: 19236 REGISTER
Proxy-Authorization: Digest username="x4zmd3m",realm="3CXPhoneSystem",nonce="414d535c108d438965:03d86a11b4f959933934e60bbdf1cdf3",uri="sip:192.168.201.10:5060",algorithm=MD5,response="a0846c9b43fc68471413cf8d37dab5eb"
Supported: replaces
User-Agent: Cisco/SPA504G-7.5.2c
Content-Length: 0
02/08/2018 2:26:49 PM - Updating device Dev(1755985719):[sip:[email protected]:5060 / 210] by message: DevUpd Recv Req REGISTER from 192.168.201.108:5060 tid=-7834586c [email protected]:
Via: SIP/2.0/UDP 192.168.201.108:5060;branch=z9hG4bK-7834586c
Max-Forwards: 70
Contact: "Micah Rayner" <sip:[email protected]:5060>;expires=120
To: "Micah Rayner" <sip:[email protected]>
From: "Micah Rayner"<sip:[email protected]>;tag=eef27efeba459afco0
CSeq: 13444 REGISTER
Proxy-Authorization: Digest username="f5b87ym",realm="3CXPhoneSystem",nonce="414d535c108d438912:52172157f76a1baf7afa2175b26042c3",uri="sip:192.168.201.10:5060",algorithm=MD5,response="49fc453869e71e7d3a67911c1386b798"
Supported: replaces
Content-Length: 0
02/08/2018 2:26:47 PM - Updating device Dev(1997609936):[sip:[email protected]:5483;rinstance=d561af2faf4a953c / 700] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=4d139f3085585259 Call-ID=Ut_1XfsGCuzQK_Dic0_P9A..: REGISTER sip:127.0.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---4d139f3085585259;rport=5483 Max-Forwards: 70 Contact: <sip:[email protected]:5483;rinstance=d561af2faf4a953c> To: "Conference Room700:"<sip:[email protected]:5060> From: "Conference Room700:"<sip:[email protected]:5060>;tag=5356d669 Call-ID: Ut_1XfsGCuzQK_Dic0_P9A.. CSeq: 434 REGISTER Expires: 60 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="700",realm="3CXPhoneSystem",nonce="414d535c108d438785:d4a9ea82ffbd5bd5614d41ee27787422",uri="sip:127.0.0.1:5060",response="b3053ec0588c480f6b3e293f8aa33316",algorithm=MD5 Supported: replaces User-Agent: 3CX Conference Room Content-Length: 0
02/08/2018 2:26:47 PM - Default IP is configured (SIPINTERFACEIP) as 192.168.201.10
02/08/2018 2:26:43 PM - Updating device Dev(588383742):[sip:[email protected]:5060 / 211] by message: DevUpd Recv Req REGISTER from 192.168.201.111:5060 tid=-96f9adde [email protected]:
Via: SIP/2.0/UDP 192.168.201.111:5060;branch=z9hG4bK-96f9adde
Max-Forwards: 70
Contact: "Rodney Ballard" <sip:[email protected]:5060>;expires=120
To: "Rodney Ballard" <sip:[email protected]>
From: "Rodney Ballard"<sip:[email protected]>;tag=42a68456f71595a0o0
CSeq: 60419 REGISTER
Proxy-Authorization: Digest username="08bx3gp",realm="3CXPhoneSystem",nonce="414d535c108d438311:ad878e31d0afa35744e93de7c77d04c3",uri="sip:192.168.201.10:5060",algorithm=MD5,response="66da77e5f12353a07c73ecb9f23dd2c6"
Supported: replaces
Content-Length: 0
02/08/2018 2:26:38 PM - Currently active calls - 1: [96]
02/08/2018 2:26:36 PM - Default IP is configured (SIPINTERFACEIP) as 192.168.201.10
