Outbound Call disconnects with ACK is not received
Discussion in '3CX Phone System - General' started by mdelaurell, Jun 10, 2008.
  1. mdelaurell
    Jun 10, 2008
    We have started using the 3CX PBX to determine it's usefulness. We are using VOIPGO as our provider and not have the extensions set up as well as the VOIP provider. We are running into an issue when making an outbound call through the provider. We initially connect to the callee, yet are disconnected after approximately 30 seconds. The log returns the following just before disconnecting the line:
    InviteADS::eek:n AckNotReceived
    Message: [CM50318]: Call(20) ACK is not received
    I need some assistance to ensure out going calls are not droped after the initial connection is made. :?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If you're making outbound call to voip provider - than PBX sends ACK. If it tells that ACK is not received in this case it can only mean that calling phone (originator of the call) didn't sent an ACK. What phone do you use?
  3. mdelaurell
    Jun 10, 2008
    This is also happening on calls from extension to extension. We are using the 3cx client to call a cell number or the 3cx client to call an Xlite client ext. to ext. This seems like a setup/configuration setting to me. I am reviewing documentation and attempting to determine these settings.
    We are using X-lite soft phone as well as calling from an external cell phone or landline extension.
    Thanks,
    Mike
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Make sure you're using local settings for 3CX VoIP Client if it resides in local network.
  5. mdelaurell
    Jun 10, 2008
    All clients are external to the local network.
    I have added this from the server. I can provide additional log entries if needed...
    10:45:50.764 Call::Terminate [CM503008]: Call(1): Call is terminated
    10:45:50.670 Call::Terminate [CM503008]: Call(1): Call is terminated
    10:45:50.545 Call::Terminate [CM503008]: Call(1): Call is terminated
    10:45:50.483 InviteADS::eek:nAckNotReceived [CM503018]: Call(1): ACK is not received
    10:45:20.717 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@10.1.10.105:5060 with contact sip:8888@10.1.10.105:5100;user=phone
    10:45:20.202 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    10:45:18.264 CallCtrl::eek:nLegConnected [CM503007]: Call(1): Device joined: sip:3039971555@66.49.255.51:5060
    10:45:18.233 CallCtrl::eek:nLegConnected [CM503007]: Call(1): Device joined: sip:1001@75.71.51.204:5070;rinstance=7573a254104ca46a
    10:45:18.217 MediaServerReporting::SetRemoteParty [MS210003] C:1.1:Answer provided. Connection(transcoding mode):75.148.140.46:9000(9001)
    10:45:18.217 MediaServerReporting::SetRemoteParty [MS210001] C:1.2:Answer received. RTP connection: 66.49.255.51:18008(18009)
    10:45:18.217 CallLeg::setRemoteSdp Remote SDP is set for legC:1.2
    10:45:09.952 Line::printEndpointInfo [CM505003]: Provider:[VOIPGo] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] Transport: [sip:10.1.10.105:5060]
    10:45:09.952 CallCtrl::eek:nAnsweredCall [CM503002]: Call(1): Alerting sip:3039971555@66.49.255.51:5060
    10:45:09.498 MediaServerReporting::SetRemoteParty [MS210002] C:1.2:Offer provided. Connection(transcoding mode): 75.148.140.46:9002(9003)
    10:45:09.342 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: VoIPline:10000@[Dev:sip:3039971555@66.49.255.51:5060]
    10:45:09.280 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:93034826856@75.148.140.46:5060]
    10:45:09.264 MediaServerReporting::SetRemoteParty [MS210000] C:1.1:Offer received. RTP connection: 75.71.51.204:42000(42001)
    10:45:09.264 CallLeg::setRemoteSdp Remote SDP is set for legC:1.1
    10:45:09.264 Extension::printEndpointInfo [CM505001]: Ext.1001: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone v5.1] Transport: [sip:10.1.10.105:5060]
    10:45:08.811 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.1001 to [sip:93034826856@75.148.140.46:5060]
    10:45:06.358 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:93034826856@75.148.140.46:5060 SIP/2.0
    Via: SIP/2.0/UDP 75.71.51.204:5070;branch=z9hG4bK-d87543-29527427453d0e2d-1--d87543-;rport=5070
    Max-Forwards: 70
    Contact: [sip:1001@75.71.51.204:5070]
    To: [sip:93034826856@75.148.140.46:5060]
    From: "3CXPhone"[sip:1001@75.148.140.46:5060];tag=cc0afe6c
    Call-ID: MWI4NTI1NDhkN2FjZGE3NjA1Yzk3NmU5MDYwNzEwYjg.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, NOTIFY, REFER, OPTIONS
    Proxy-Authorization: Digest username="1001",realm="3CXPhoneSystem",nonce="12859577105:35298a0152af5f0caa4e9e301f697d3f",uri="sip:93034826856@75.148.140.46:5060",response="cce490d25e6a89570e3633e38357d6b6",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX Phone v5.1
    Content-Length: 0
  6. mdelaurell
    Jun 10, 2008
    Please view the entry above with the additional information :shock:
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    We do not provide technical support on this forum.
