outbound call drops after about 30 seconds
Discussion in 'Windows' started by aftermarket, May 25, 2010.
  1. aftermarket
    May 13, 2009
    84
    running the spa 504g incoming calls are fine however when we place calls they drop out after about 30 seconds, any ideas??
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Logs?
  3. aftermarket
    May 13, 2009
    84
    sorry, heres the logs:
    18:21:18.150 [CM503008]: Call(13): Call is terminated
    18:21:18.145 [CM503021]: Call(13): ACK is not received
    18:21:08.853 Active calls counted toward license limit: [13]
    18:20:46.114 [CM503007]: Call(13): Device joined: sip:3818135@sipgate.co.uk:5060
    18:20:46.110 [CM503007]: Call(13): Device joined: sip:100@88.104.xxx.xxx:5060
    18:20:42.552 [CM505003]: Provider:[sipgate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:3818135@80.176.xxx.xxx:5060]
    18:20:42.551 [CM503002]: Call(13): Alerting sip:3818135@sipgate.co.uk:5060
    18:20:37.147 [CM503025]: Call(13): Calling VoIPline:07738378515@(Ln.10001@sipgate)@[Dev:sip:3818135@sipgate.co.uk:5060]
    18:20:36.971 [CM503004]: Call(13): Route 3: VoIPline:07738378515@(Ln.10001@sipgate)@[Dev:sip:3818135@sipgate.co.uk:5060]
    18:20:36.970 [CM503004]: Call(13): Route 2: VoIPline:07738378515@(Ln.10001@sipgate)@[Dev:sip:3818135@sipgate.co.uk:5060]
    18:20:36.970 [CM503004]: Call(13): Route 1: VoIPline:07738378515@(Ln.10001@sipgate)@[Dev:sip:3818135@sipgate.co.uk:5060]
    18:20:36.968 [CM503010]: Making route(s) to "07738378515"<sip:07738378515@80.176.xxx.xxx>
    18:20:36.965 [CM505001]: Ext.100: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA504G-7.4.4] PBX contact: [sip:100@80.176.150.94:5060]
    18:20:36.961 [CM503001]: Call(13): Incoming call from Ext.100 to "07738378515"<sip:07738378515@80.176.xxx.xxx>
    18:20:36.853 Active calls counted toward license limit: []
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    It is the reason to drop the call. "ACK" is not received from the phone(Ext.100) which is remote.
    Verbose logs or wireshark capture can provide more information for troubleshooting.
  5. aftermarket
    May 13, 2009
    84
    hi,
    do you have any rough ideas of a setting it could be before i start messing with wireshark which i have no understanding of lol. thanks for your help so far
  6. leejor
    11,113
    329
    Can Ext. 100 make successful calls to other extensions?
