Outbound Call Flow Example
Discussion in 'Call Flow Designer' started by Eric Osborn, Oct 22, 2017.
  1. Eric Osborn
    Mar 24, 2017
    27
    In the example it states "we’ll increment the CallIndex, using another Launch External Script component" but doesn't show how to do so? Did I miss something?
    Thanks,
    Eric
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,693
    134
    Hi Eric,
    You can check the sample app provided in "Documents\3CX Call Flow Designer Demos\OutboundDialerDemo", there you have all the details. You just need to add a Launch External Script component and configure it almost in the same way than with component "getCallIndex", just changing the method name.
    Kind regards.
    Mohammed alnimr likes this.
