outbound call gets fast busy with Voxitas
Discussion in '3CX Phone System - General' started by rjtx667, Jun 10, 2009.
  1. rjtx667
    Nov 14, 2007
    I have configured a new 3cx install to use a VoIP Provider (Voxitas)
    Inbound calls work fine, as well as extension to extension, but I am unable to get outbound calls to work.
    I do not think it is a problem with out outbound rule as it appears to be sending a call to Voxitas, but appears to get an error after that.
    Any help is greatly appreciated.
    Ryan
    Here is a copy of some logs:
    23:49:23.807 [CM503008]: Call(46): Call is terminated
    23:49:20.557 [CM505003]: Provider:[Voxitas] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NetLogic Switch v3.2.3] Transport: [sip:xx.xx.xx.xx:5060]
    23:49:20.557 [CM503002]: Call(46): Alerting sip:sipuser@dal02a.netlogic.net:5060
    23:49:19.135 [CM503024]: Call(46): Calling VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipuser@dal02a.netlogic.net:5060]
    23:49:18.979 [CM503004]: Call(46): Route 1: VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipuser@dal02a.netlogic.net:5060]
    23:49:18.979 [CM503010]: Making route(s) to "9817xxxxxxx"<sip:9817xxxxxxx@xx.xx.xx.xx>
    23:49:18.963 [CM505001]: Ext.101: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1014k stamp 47051] Transport: [sip:xx.xx.xx.xx:5060]
    23:49:18.947 [CM503001]: Call(46): Incoming call from Ext.101 to "9817xxxxxxx"<sip:9817xxxxxxx@xx.xx.xx.xx>
    23:43:35.868 [CM503008]: Call(45): Call is terminated
    23:43:33.071 [CM505003]: Provider:[Voxitas] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NetLogic Switch v3.2.3] Transport: [sip:xx.xx.xx.xx:5060]
    23:43:33.071 [CM503002]: Call(45): Alerting sip:sipuser@dal02a.netlogic.net:5060
    23:43:31.665 [CM503024]: Call(45): Calling VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipuser@dal02a.netlogic.net:5060]
    23:43:31.400 [CM503004]: Call(45): Route 1: VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipuser@dal02a.netlogic.net:5060]
    23:43:31.384 [CM503010]: Making route(s) to "9817xxxxxxx"<sip:9817xxxxxxx@xx.xx.xx.xx>
    23:43:31.384 [CM505001]: Ext.101: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1014k stamp 47051] Transport: [sip:xx.xx.xx.xx:5060]
    23:43:31.368 [CM503001]: Call(45): Incoming call from Ext.101 to "9817xxxxxxx"<sip:9817xxxxxxx@xx.xx.xx.xx>
    23:41:11.931 [CM503008]: Call(44): Call is terminated
    23:41:10.212 [CM505003]: Provider:[Voxitas] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NetLogic Switch v3.2.3] Transport: [sip:xx.xx.xx.xx:5060]
    23:41:10.212 [CM503002]: Call(44): Alerting sip:sipuser@dal02a.netlogic.net:5060
    23:41:08.697 [CM503024]: Call(44): Calling VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipname@dal02a.netlogic.net:5060]
    23:41:08.603 [CM503004]: Call(44): Route 1: VoIPline:817xxxxxxx@(Ln.10000@Voxitas)@[Dev:sip:sipnames@dal02a.netlogic.net:5060]
    23:41:08.587 [CM503010]: Making route(s) to "9817xxxxxxx"<sip:9817xxxxxxx2@xx.xx.xx.xx>
    23:41:08.587 [CM505001]: Ext.101: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1014k stamp 47051] Transport: [sip:xx.xx.xx.xx:5060]
    23:41:08.572 [CM503001]: Call(44): Incoming call from Ext.101 to "9817xxxxxxx"<sip:9817xxxxxxx@xx.xx.xx.xx>
    23:40:00.197 [CM504001]: Ext.104: new contact is registered. Contact(s): [sip:104@xx.xx.xx.xx:52808;user=phone;transport=udp/104]
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello.
    do you trie your voip provider with only voip client like xlite.
    test this and if it's don't work, you that a provider problem, if not can you explain your 3cx installation please
    have good day
  3. leejor
    10,732
    277
    Not sure what the dialing plan is in your area. You are sending an "8" as the first digit. Do they require a "1" or a "0" perhaps?
    Just had a look, it seems Voxitas is in the US so i suspect you have to add a "1' in front of your outgoing digits.
    You can have 3CX do that automatically for you in the outgoing dial rules.
  4. rjtx667
    Nov 14, 2007
    After trying to login with just the x-lite client I found it could not make an outbound call from that.
    After doing several variations and some googleing I found out that Voxitas uses E.124 numbering which sound be +1xxx-xxx-xxxx
    this did not work, however +11xxx-xxx-xxxx did work.
    So I modified the dial plan to strip the 9 out and prepend a +11.
    I just have to remember to never add a 1 to a long distance number, but otherwise I would have to add a 1 to all outbound calls.
    Thanks for all your help,
    Ryan
  5. leejor
    10,732
    277
    You could set up a second outgoing rule that would handle calls dialled with a "1" (91XXXXXXXXXX) then you wouldn't have to worry.
    After thinking about that...you'd have to create a rule for each of the other 9 combinations, 92,93,94,95...etc to only strip the 9 and prepend +11. then a rule for 91 to strip 2 digits and prepend with +11. Or you might be able to base it on the length of digits dialled.
    Or, require 91 for any non-local area code, if you are required to dial 10 digits locally, and have a rule for all local numbers beginning with 9+ the first digit of the local area code. Or, 1+ for long distance and 9+ for local.
