Outbound call gives proxy authentication error
Discussion in '3CX Phone System - General' started by epobeee, Dec 8, 2010.
  1. epobeee
    Dec 8, 2010
    hi i am confused and dont know what else to do, may be someone can help.
    i am using the 3CX phone system and i can recieve inbound call without any problem however when i try to call outside i get authentication failed,
    proxy authentication error and the call is disconnected. however the phone i'm trying to reach does recieve the call but cant hear me.
    i'm using a VOIP provider called XELOQ
    can anyone help me.
    23:01:44.408 [CM503008]: Call(2): Call is terminated
    23:01:37.310 [CM503007]: Call(2): Device joined: sip:2100@41.218.103.35:5060;line=25107
    23:01:37.310 [CM503002]: Call(2): Alerting sip:EndCall@127.0.0.1:40600;rinstance=e23203a553e1c02a
    23:01:37.107 [CM503025]: Call(2): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=e23203a553e1c02a]
    23:01:37.107 [CM503003]: Call(2): Call to sip:00233244560005@sip.unitalks.com:5060 has failed; Cause: 407 Proxy Authentication Required; from IP:81.26.212.150:5060
    23:01:35.859 [CM505003]: Provider:[sip.unitalks.com] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:735246@41.218.103.34:5060]
    23:01:35.859 [CM503002]: Call(2): Alerting sip:735246@sip.unitalks.com:5060
    23:01:34.096 [CM503025]: Call(2): Calling VoIPline:00233244560005@(Ln.10000@sip.unitalks.com)@[Dev:sip:735246@sip.unitalks.com:5060]
    23:01:34.050 [CM503004]: Call(2): Route 1: VoIPline:00233244560005@(Ln.10000@sip.unitalks.com)@[Dev:sip:735246@sip.unitalks.com:5060]
    23:01:34.034 [CM503010]: Making route(s) to <sip:00233244560005@41.218.103.34>
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Do you have a Proxy address listed under the VoIp Provider within 3CX Console? if so remove it and try again.
  3. epobeee
    Dec 8, 2010
    i think you are talking about outbound proxy address?
    well there is nothing like that
