Outbound Call Route Help
Discussion in '3CX Phone System - General' started by seanc, Aug 7, 2015.
  1. seanc
    May 25, 2015
    25
    2 SIP Trunks
    Cyta and DIDlogic
    All local land line numbers and mobile numbers have 8 digits.
    i need these calls routing through Cyta SIP
    so any number that has more than 8 digits can route through DID Logic.
    We dial 0 for a line
    i get confused when it comes to striping and prepending digits.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Look at outbound rules - http://www.3cx.com/blog/voip-howto/outbound-rules-a-complete-example/
    You do not have to dial 0 for a line, can just dial the number and let the rules routes the call.
    Basically you need to create
    Rule 1 - Calls to numbers with a length of 8 route via Cyta Sip
    Rule 2- All other calls (leave apply fields blank) route via DID logic.
    You can make the rules, as complicated to suit your requirements.
  3. seanc
    May 25, 2015
    25
    thank you, it was easy in the end.
    all calls to go over didlogic UNLESS it has 8 digits
