=============================================silentfun said:81234567 to 15611234567
try
r1561 as rule
"r" turns 81234567 into 1234567
"1561" turns 1234567 into 1561 into 15611234567
each r kill one digit and each digit will be placed infront of your number
hope this helps
archie said:Dial list of 3 digits doesn't work, because your extensions has 3 digit long numbers. So, any 3 digits dials are treated as internal number.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
