Outbound Call Rules
Martink
I got 4 PSTN lines thru Patton 4114.
Only on one line, we have long distance.
Any idea how to route long distance calls to this specific line???
I would think to create a rule of dialing
e.g. anything that starts with 1201 goes through lines 1-3 everything else through line 4. This way line 4 is always free to take long distance calls.
Good Luck,
Let me know how it turns out.
Alon
Alon
There is no choice line 1-3.
Only choice I have is Gateway wich has 4 lines.
ah... I thought you were asking for the logic behind the rule.
I have no idea how to help you there.
Would love to know what you did, I have a similar problem.
In my case we are using different suppliers, so I don't think I will have this issue.
Good Luck!!!
Alon
Is it possible to remove the one line from that gateway.
and add it as a separate gateway?
That way it would open a choice for you.
(You may have to separate all 4 lines into separate gateways)
Try it, let me know.
Yes, however this is unsupported and is known to generate problems.
Getting Started - Admin
Daniel Acosta
Get 3CX - Absolutely Free!
3CX
