Outbound call Through Patton SN4114 Not working
Discussion in '3CX Phone System - General' started by Network Emad, Nov 20, 2017.
  1. Network Emad
    Oct 27, 2017
    33
    dear
    already the link between the 3CX and Patton SN4114 Gateway active and showing green sign in SIP trunk in 3CX. My Issue that i Can receive any call from outside but i cant dial or call any one outside. i got this message through Snom LCD screen: Internal Server Error.
    kindly find the captured packet through WireShark attached with this conversation.
    thanks
    #1 Network Emad, Nov 20, 2017
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,095
    165
    Have you set up outbound rules to dial via Patton SN4114
    YiannisH_3CX likes this.
  3. Network Emad
    Oct 27, 2017
    33
    hello Saqqara
    hey I did that in 3CX. first I created the SIP Trunk as shown here in this website and I got the green sign. it's mean the link between 3CX server and Patton SN4114 it's working properly after that I created the inbound rule in 3CX (From Patton) it's working perfectly. after that I created the Outbound Rule in 3CX it's not working. for more information already all required ports on fire are open. and
    before starting with Patton SN4114 I was using GSM Gateway the outbound and Inbound Rules working properly.
    regarding ur question if I created the outbound rule to dial via patton sn4114....... yes I did that
    thanks
  4. Network Emad
    Oct 27, 2017
    33
    Disconnected
    Server Internal Error:0582449938 ------ this is the called number
  5. Network Emad
    Oct 27, 2017
    33
    # For Patton 2 to 8 FXO
    # Supported firmware versions R6.x
    # Author: Tommaso Missoni
    # Contact: support@patton.com
    webserver port 80 language en
    system
    ic voice 0
    low-bitrate-codec g729
    sntp-client
    sntp-client server primary pool.ntp.org
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 1000 425 -6
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 1000 425 -13
    pause 2 4000
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 300 425 -7
    pause 2 200
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 300 425 -7
    pause 2 400
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    play 1 300 425 -7
    pause 2 400
    profile tone-set default
    profile voip default
    codec 1 g711ulaw64k rx-length 20 tx-length 20 silence-suppression
    codec 2 g711alaw64k rx-length 20 tx-length 20 silence-suppression
    codec 3 g729 rx-length 20 tx-length 20 silence-suppression
    fax transmission 1 relay t38-udp
    profile pstn default
    echo-canceler-hybrid-loss 0
    echo-canceler-nlp silence
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface IF_IP_LAN
    ipaddress 10.2.2.80 255.255.255.0
    context cs switch
    routing-table called-e164 RT_SIP_TO_FXO
    route .% dest-service HG_TO_FXO
    routing-table called-e164 RT_FXO_00_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_00
    routing-table called-e164 RT_FXO_01_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_01
    routing-table called-e164 RT_FXO_02_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_02
    routing-table called-e164 RT_FXO_03_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_03
    mapping-table called-e164 to called-e164 MT_CALL_ID_00
    map .% to 000000
    mapping-table called-e164 to called-e164 MT_CALL_ID_01
    map .% to 000001
    mapping-table called-e164 to called-e164 MT_CALL_ID_02
    map .% to 000002
    mapping-table called-e164 to called-e164 MT_CALL_ID_03
    map .% to 000003
    service hunt-group HG_TO_FXO
    cyclic
    drop-cause destination-out-of-order
    drop-cause user-busy
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_FXO_0
    interface sip IF_SIP
    bind context sip-gateway GW_SIP
    early-disconnect
    route call dest-table RT_SIP_TO_FXO
    remote 10.2.2.2 5060
    trust remote
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
    interface fxo IF_FXO_0
    route call dest-table RT_FXO_00_TO_SIP
    loop-break-duration min 60 max 1000
    caller-id format etsi
    ring-number on-caller-id
    mute-dialing
    disconnect-signal loop-break
    disconnect-signal busy-tone
    dial-after dialtone
    interface fxo IF_FXO_1
    route call dest-table RT_FXO_01_TO_SIP
    mute-dialing
    dial-after dialtone
    interface fxo IF_FXO_2
    route call dest-table RT_FXO_02_TO_SIP
    mute-dialing
    dial-after dialtone
    interface fxo IF_FXO_3
    route call dest-table RT_FXO_03_TO_SIP
    mute-dialing
    dial-after dialtone
    context cs switch
    no shutdown
    authentication-service AS_ALL_LINES
    realm 1 3CXPhoneSystem
    username 10000 password w5tvrva
    location-service LS_10000
    domain 1 10.2.2.2
    identity-group default
    authentication outbound
    authenticate 1 authentication-service AS_ALL_LINES username 10000
    identity 10000
    registration outbound
    registrar 10.2.2.2 5060
    lifetime 60
    register auto
    register auto
    interface LAN
    bind interface IF_IP_LAN context router port 5060
    bind location-service LS_10000
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_LAN router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    bind interface IF_IP_WAN router
    no shutdown
    port fxo 0 0
    use profile fxo etsi
    encapsulation cc-fxo
    bind interface IF_FXO_0 switch
    no shutdown
    port fxo 0 1
    bind interface IF_FXO_1 switch
    no shutdown
    port fxo 0 2
    bind interface IF_FXO_2 switch
    no shutdown
    port fxo 0 3
    bind interface IF_FXO_3 switch
    no shutdown
    context cs
    no IF_FXO_1
    no IF_FXO_2
    no IF_FXO_3
    port fxo 0 1
    shutdown
    port fxo 0 2
    shutdown
    port fxo 0 3
    shutdown
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Please let us know what firmware is the Patton device running and attach a screenshot of your outbound rules if possible. Also did you use the config file from 3CX to provision the Patton device?
    Network Emad likes this.
  7. mic.max
    Nov 24, 2010
    56
    try to modify on FXO interface "dial-after dialtone" with dial-after 1 second !
    Is possible the tone are not correct for your telephone line.
  8. Network Emad
    Oct 27, 2017
    33
    dear all thanks for ur replay
    yes mr. YiannisH_3CX I used this firmware from the patton website. this is the update title ((SmartWare 6.9 Build Series 2017-05-04)) from here: https://www.patton.com/support/upgrades/index.asp?um=SmartNode 411x
    regarding the outbound rule already created on 3CX to be pass through patton sn4114. just for more information I have fixed GSM Gateway and it was working properly for inbound and outbound call without any issues.
  9. Network Emad
    Oct 27, 2017
    33
    already when create new SIP Trunk on 3CX and click ok the Configuration file will be downloaded on my PC and Patton sn4114 open new tab on the browser. after that I start importing the new configuration and reload the device.
  10. Network Emad
    Oct 27, 2017
    33
    ok I'll try it now and inform you
    thanks
