Outbound call timeout
Discussion in '3CX Phone System - General' started by daktur, Jan 5, 2018.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I have setup a new provider however, sometimes the outbound call attempt times out without getting connected.
    My provider reviewed and looks like normal on their end. Is it possible to extend the duration of the attempt before timimng out?
    Thanks!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @daktur
    Please note that 3CX will drop the call after 32 seconds if no ACK is received which cannot be changed. Does the call time out while it is ringing or is it dead air? And where is call getting dropped from? Do you see the BYE message from the 3CX side?
  3. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi @YiannisH_3CX ,
    Tha call fails dead in the air.
    This is the log for the call that failed:
    01/06/2018 2:42:01 PM - Call to T:Line:10002>>000005511981934567@[Dev:sip:<IP>@sip.<PROVIDER>.com:5060] from L:3112.1[Extn:001] failed, cause: Cause: 480 Temporarily not available/INVITE from 77.72.174.128:5060
    01/06/2018 2:42:01 PM - [CM503003]: Call(C:3112): Call to <sip:000005511981934567@sip.<PROVIDER>.com:5060> has failed; Cause: 480 Temporarily not available/INVITE from <IP>:5060
    But for other numbers it works just fine.
    Looking forward to hear from you.
    Thanks,
    Ariel.
  4. leejor
    10,767
    286
    This indicates just what it says. That number is not available, for some reason. The message is sent from your provider. They probably won't be able to provide any additional information as they will see the same message to whoever they pass the call onto.
  5. YiannisH_3CX
    May 10, 2016
    6,016
    421
    as leejor mentioned this message originates from your provider indicating that the number is not available. The only thing you can do from your side is to make sure that the dialled number is correct.
