Outbound Call
Discussion in '3CX Phone System - General' started by Sakib, Dec 22, 2006.
  1. Sakib
    Dec 21, 2006
    14
    How to Dial a Outbound call using a VoIP Gateway?? if someone whishes to dial a PSTN number from the 3CX network doent he have to dial a number before to access the PSTN line ?? Okey I have added a VoIP gateway for test purpose but i am kinda blind how to dial a out bound PSTN number from the network. Please help.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Prefix
    To make an outbound call, you would have to enter a prefix. By default this prefix is zero - and this will be associated with the first VOIP Gateway you configured. You can go to the outbound rules section and configure this differently if you want.
  3. Sakib
    Dec 21, 2006
    14
    Re: Prefix
    Dear Admin Thanks for your reply. I was wondering if you could give me an Example Call Rule for out bounds. I would like to set number 9 as a prefix to use the VoIP gateway for outbound calls. Sorry for being confused. Your help is much appreciated.
  4. Nick Galea
    Jun 6, 2006
    2,007
    312
    Call Rule
    Of course!
    1. Create a new outbound rule
    2. Give it a name
    3. enter number 9 in Calls starting with
    4. Select VOIP Gateway or VOIP provider you want to use for calls
    5. Enter "r" in the transform mask - this will remove the 9 from the number to dial.
    OK to continue and you should be all set...
