Solved Outbound Caller ID - 3CX with Callcentric
Discussion in '3CX Phone System - General' started by ajohnson443, Aug 26, 2017.
  1. ajohnson443
    Mar 27, 2012
    30
    I have multiple DID's configured on my 3CX system. I need for some of them to send the caller-id specific to that extension instead of the pilot number configured on the callcentric trunk extension.
    I am using 3CX PBX Version 15.5.5.
    My VoIP trunk is a callcentric trunk with caller-id set to the primary business DID
    My 3CX outbound parameters have been set as requested by Callcentric:
    P-Asserted Identity : User Part - “OutboundCallerId”
    P-Asserted Identity : Host Part - “OutHostPort”
    The problem seems to be limited to a couple of analog extensions hanging off Cisco SPA122's
    The SPA122s register just fine, inbound and outbound calling works fine. I just can't figure out how to make the correct caller-id pass from those extensions.
    Any ideas?
  2. ajohnson443
    Mar 27, 2012
    30
    Ok - Figured it out.. It was my mistake lol....
    In the caller ID settings per extension you MUST use ALL 11 digits of the outbound caller-id.. I had accidentally forgotten to add the "1" before the area code... DOH! :oops::oops:
    I'll leave this post up for any other 3CX newbies ;)
