Outbound caller id - format problem
Discussion in '3CX Phone System - General' started by mart3cx, Aug 29, 2011.
  1. mart3cx
    Jul 1, 2010
    19
    i have following question/problem:
    My VoIP provider needs the outbound caller id of the extension in following format:
    <sip:01299999101@p1.voip.inode.at:5060>
    01299999 is the phone number
    101 is the extension.
    At the moment he gets:
    "012999999101" <sip:01299999@p1.voip.inode.at:5060>
    and so only the main number without extension is shown on outside calls.
    012999999101 is the value of the outbound caller id in the extension.
    Which parameters must be or in which format must i set the outbound caller id so that also the extension 101 is transfered in the correct format.
    Called party should see 012999999101 on display.
    TX
    Mart
  2. FITEC
    Sep 15, 2008
    19
    use search and find the answer at http://www.3cx.com/forums/ausgehende-nebenstelle-wird-nicht-mitgesendet-upc-inode-20890.html#p109355
