Outbound Caller ID format
Discussion in '3CX Phone System - General' started by bolive, Apr 30, 2014.
  1. bolive
    Apr 30, 2014
    Hello everyone
    I am trying to set the outbound caller id with a name and number. Does anyone know the format?
    Brian
    11,277
    360
    The format, for where? In north America, it's usually a 10 digit number.
    Many providers do not allow you the option of sending a name.
  3. bolive
    Apr 30, 2014
    Sorry yes we are in north America. If my provider does allow it, is there a special format for the outbound caller id field?
  4. leejor
    11,277
    360
    Caller name, over the PSTN network, is usually limited to 15 characters. I would stick with using only the 26 letters, and zero to 9 , as well as a space. Some receiving devices have been discovered, in the past, to have issues when any punctuation characters are used. You are best to confirm all of this with your provider.
