Outbound Caller ID
Discussion in '3CX Phone System - General' started by gmintoff, Sep 15, 2011.
  1. gmintoff
    Sep 15, 2011
    I am having a little problem in sending the outbound caller id when doing external calls.
    I am using the following version v10.0.20401.1947 SP.2 as a freeware for testing.
    I have set the Outbound Caller ID in Extension Status\Other to be the full number. Any other setting that i should be looking at.
    Any help would be greatly appreciated.
    Glenn
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Check the outbound parameters settings for the provider - use ID sent for From: user part and Contact:
    Regards
  3. leejor
    10,869
    304
    What type of service are you using for your outbound calls? Changing outbound caller ID will only work on VoIP trunks AND only if your provider allows (supports) it.
