Outbound caller id
Discussion in '3CX Phone System - General' started by matthijsolislagers, Feb 23, 2008.
  1. matthijsolislagers
    matthijsolislagers New Member
    140
    I have the following setup:
    3CX Server
    SmartNode 4554 ISDN Gateway
    2 IDSN lines
    8 Telephone numbers
    10 Grandstream phones
    Line 1
    Number 1: 11111111
    Number 2: 22222222
    Number 3: 33333333
    Number 4: 44444444
    Line 2
    Number 1: 55555555
    Number 2: 66666666
    Number 3: 77777777
    Number 4: 88888888
    When someone calls per example on the number 88888888 I have created a DID number which is forwarded to extension 15. This all works fine. But when extension 15 calls outside the receiving party gets 55555555 as caller ID. The main number of the line.
    Is it possible to choose a DID number for a outbound call so the correct caller ID is displayed???
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your post.
    In the 3CX UI > Extentions > Manage > extention number > options did you set the outbound caller ID to the desired number for that user?
  3. matthijsolislagers
    140
    That worked indead. Thanks. Stupid I didn't figure that out myself.
