Solved Outbound Caller ID
Discussion in '3CX Phone System - General' started by GabrielVE, Feb 22, 2017.
  1. GabrielVE
    Oct 25, 2016
    31
    Hi All!
    We have 1 SIP Trunk, and Several DIDs on it
    Is it possible to assign a specific Caller ID based on the Local Code of the person whom we're calling?
    Sample Scenario
    DIDs:
    01 1234567
    02 2345678
    03 3456789
    If a staff calls a Phone number with a 01 local, then the Caller ID will be 01 1234567... If a staff calls in a Phone number with a 02 local, the Caller ID will be 02 2345678 and so on
    Thanks in Advance!
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi GabrielVE,
    If I understand correctly, you want to have the ability to choose what callerID number appears to the callee, is that correct?
    I am afraid this can't be achieved with one trunk, this can be achieved only if you are using multiple trunks and caller ID reformating.
    You can find more details on this link https://www.3cx.com/blog/docs/cid-formatting/
    CallerID:
    01 rule name => Route Trank name 01 => CallerID :1234567
    02 rule name => Route Trank name 02 => CallerID :2345678
    03 rule name => Route Trank name 03 => CallerID :3456789
  3. GabrielVE
    Oct 25, 2016
    31
    Hi Giannos,
    If I have multiple trunk lines, can I then assign a trunk line based on the area code of the phone number that I'm calling?
    I thought this can originally be configured with one trunk line but with multiple DIDs using the Caller ID formatting
    Thanks,
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi GabrielVE,
    Yes, you can assign a trunk line based on the area code of the phone number if and only if your provider support the CLIR.
  5. GabrielVE
    Oct 25, 2016
    31
    And this only applies if we have Multiple Trunk lines, right?
    Thanks,
  6. Patrick Hogan10
    Nov 23, 2016
    27
    Hi Gabriel, yes, I believe this only applies if we have multiple trunk lines.
  7. GabrielVE
    Oct 25, 2016
    31
    Thanks Pat!
