- Joined
- May 29, 2012
- Messages
- 1
- Reaction score
- 0
If you are having a problem sending outbound caller-id over a T1 PRI you need to route calls going out differently.
Standard config with a Patton 4960
# SN4940/1E24V #
# R5.T 2011-01-17 H323 RBS SIP #
# 2012-04-25T18:50:15 #
# SN/00A0BA06CF7F #
# Generated configuration file #
cli version 3.20
clock local default-offset +00:00
webserver port 80 language en
system
ic voice 0
pcm law-select uLaw
system
clock-source 1 e1t1 0 0
profile r2 default
profile ppp default
profile call-progress-tone defaultDialtone
play 1 1000 350 -13 440 -13
profile call-progress-tone defaultAlertingtone
play 1 1000 440 -19 480 -19
pause 2 3000
profile call-progress-tone defaultBusytone
play 1 500 480 -24 620 -24
pause 2 500
profile call-progress-tone defaultReleasetone
play 1 250 480 -24 620 -24
pause 2 250
profile call-progress-tone defaultCongestiontone
pause 2 250
profile tone-set default
profile voip default
codec 1 g711ulaw64k rx-length 20 tx-length 20
codec 2 g711alaw64k rx-length 20 tx-length 20
rtp traffic-class local-default
dejitter-mode static-data
dejitter-max-delay 30
fax transmission 1 bypass g711ulaw64k
profile pstn default
profile sip default
no autonomous-transitioning
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
ipaddress 172.21.0.254 255.255.252.0
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
context ip router
route 0.0.0.0 0.0.0.0 172.21.0.1 2
context cs switch
routing-table called-e164 RT_ISDN_TO_SIP_0
route default dest-interface IF_SIP_0 MAPPING_INCOMING_CALLS
mapping-table calling-pi to calling-e164 MAP_REMOVE_BLANK_CALLERID
map restricted to ""
mapping-table calling-e164 to calling-e164 MAP_LEADING_ZERO
map (.%)-(.%)-(.%)-(.%)-(.%) to \1\2\3\4\5
map (.%)-(.%)-(.%)-(.%) to \1\2\3\4
map (.%)-(.%)-(.%) to \1\2\3
map (.%)-(.%) to \1\2
mapping-table calling-e164 to calling-name MAP_CID_TO_CNAME
map (.%) to \1
complex-function MAPPING_INCOMING_CALLS
execute 1 MAP_REMOVE_BLANK_CALLERID
execute 2 MAP_LEADING_ZERO
execute 3 MAP_CID_TO_CNAME
interface isdn IF_ISDN_0
route call dest-table RT_ISDN_TO_SIP_0
caller-name
user-side-ringback-tone
interface sip IF_SIP_0
bind context sip-gateway GW_SIP_0
route call dest-interface IF_ISDN_0
remote 172.21.1.1 5060
early-connect
early-disconnect
address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
context cs switch
no shutdown
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10000 password A5ICoOdB/ZCMGfO1otfZEA== encrypted
location-service LS_10000
domain 1 172.21.1.1
identity-group default
authentication outbound
authenticate 1 authentication-service AS_ALL_LINES username 10000
identity 10000
registration outbound
registrar 172.21.1.1 5060
lifetime 300
register auto
interface LAN
bind interface IF_IP_LAN context router port 5060
bind location-service LS_10000
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
bind interface IF_IP_LAN router
no shutdown
port e1t1 0 0
port-type t1
clock auto
linecode b8zs
framing esf
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol ni2
uni-side user
bchan-number-order ascending
encapsulation cc-isdn
bind interface IF_ISDN_0 switch
port e1t1 0 0
no shutdown
What you need to do is to create a routing table and two mapping-tables. You also need a complex function.
routing-table called-e164 SIP_TO_ISDN
route .% dest-interface IF_ISDN_0 ChangCallerID
mapping-table calling-type-of-number to calling-type-of-number MAP-SET-National
map unknown to national
mapping-table calling-numbering-plan to calling-numbering-plan MAP-SET-Numbering
map unknown to isdn-telephony
Now your complex function.
complex-function ChangCallerID
execute 1 MAP-SET-National
execute 2 MAP-SET-Numbering
The trick is to route outgoing calls on the SIP interface.
route call dest-table SIP_TO_ISDN
I hope this helps.
Working Config.
cli version 3.20
system
ic voice 0
pcm law-select uLaw
system
profile r2 default
profile ppp default
pause 2 3000
pause 2 500
pause 2 250
pause 2 250
fax transmission 1 bypass g711ulaw64k rx-length 10 tx-length 10
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
context ip router
context cs switch
map (.%) to \1
caller-name
early-connect
early-disconnect
context cs switch
no shutdown
username 10000 password A5ICoOdB/ZCMtGO1otfZEA== encrypted
domain 1 172.21.1.1
identity 10000
lifetime 300
register auto
interface LAN
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port e1t1 0 0
port-type t1
clock auto
linecode b8zs
framing esf
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol ni2
uni-side user
port e1t1 0 0
no shutdown
# SN4940/1E24V #
# SN/00A0BA06CF7F #
cli version 3.20
system
ic voice 0
pcm law-select uLaw
system
profile r2 default
profile ppp default
pause 2 3000
pause 2 500
pause 2 250
pause 2 250
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
context ip router
context cs switch
map (.%) to \1
caller-name
early-connect
early-disconnect
context cs switch
no shutdown
domain 1 172.21.1.1
identity 10000
lifetime 300
register auto
interface LAN
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port e1t1 0 0
port-type t1
clock auto
linecode b8zs
framing esf
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol ni2
uni-side user
port e1t1 0 0
no shutdown
I hope this helps.
Working Config.
cli version 3.20
system
ic voice 0
pcm law-select uLaw
system
profile r2 default
profile ppp default
pause 2 3000
pause 2 500
pause 2 250
pause 2 250
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
context ip router
context cs switch
map (.%) to \1
caller-name
early-connect
early-disconnect
context cs switch
no shutdown
domain 1 172.21.1.1
identity 10000
lifetime 300
register auto
interface LAN
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port e1t1 0 0
port-type t1
clock auto
linecode b8zs
framing esf
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol ni2
uni-side user
port e1t1 0 0
no shutdown
