outbound calls broadvoice
Discussion in '3CX Phone System - General' started by ncwtech, Mar 10, 2008.
  1. ncwtech
    Mar 10, 2008
    3CX Phone System Version5.0.3790.0
    LinkSys SPA942
    Grandstream 1404
    Since upgrading to v5 we have been having problems with outbound calls with broadvoice. This is not a outbound rules issue.
    Inbound calls during this time work without issue.
    We keep getting this error:
    Call to sip:8888888@sip.broadvoice.com has failed; Cause: 403 Forbidden; from IP:147.135.32.221
    The ip address is 'sip.broadvoice.com' and not the outbound proxy that we have set 'proxy.lax.broadvoice.com'.
    Could there be a problem with the broadvoice template?? Anyone else running into this issue? A few other posts but not resolutions.
    17:17:13.330 Call::Terminate [CM503008]: Call(11): Call is terminated
    17:17:13.315 Call::RouteFailed [CM503014]: Call(11): Attempt to reach [sip:8888888@192.168.10.12] failed. Reason: Forbidden
    13.315 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:8888888@sip.broadvoice.com has failed; Cause: 403 Forbidden; from IP:147.135.32.221
    17:17:12.627 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(11): Calling: VoIPline:10000@[Dev:sip:2068888000@sip.broadvoice.com:5060]
    17:17:12.580 CallCtrl::eek:nIncomingCall [CM503001]: Call(11): Incoming call from Ext.110 to [sip:8888888@192.168.10.12]
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Did you do a reboot? Try that first. There are more people with this problem but a different provider.
    What sytem do you use?
  3. ncwtech
    Mar 10, 2008
    We have. we have also deleted the broadvoice settings several times. We do not consider rebooting a solution however.
    The broadvoice service works for a while then fails. When it fails we see Cause: 403 Forbidden; from IP:147.135.32.221.
    3cx v5.0.3790.0 is running on an P4 3.0 w/ 1Gig of ram.
