OutBound Calls dropped unexpectedly!
Discussion in '3CX Phone System - General' started by roby78, Apr 26, 2007.
  1. roby78
    Apr 26, 2007
    i have a problem with outbound calls on pstn line. I'm using a Sipura 3000 gateway, 3CX Phone System v3.0.1699.0 and Cisco Ip phones 7960.
    Some outbounding calls (not all) over the pstn line are dropped after 32/33 seconds.
    Inbound and internal calls work perfectly.
    this is the server status log:
    11:29:32.633 StratLink::eek:nHangUp Call(C:98): got Hang-Up from Ext.207; reason: ???
    11:29:00.258 CallLegImpl::eek:nConnected Established media channel for Ln:200@Sipura 3000: remote=10.0.0.4:16470; local=:17126
    11:29:00.258 StratInOut::eek:nConnected Call from Ext.207 to Ln:200@Sipura 3000 is established
    11:29:00.258 CallLegImpl::eek:nConnected Established media channel for Ext.207: remote=:17126; local=10.0.0.4:16470
    11:29:00.039 CallConf::eek:nIncoming Incoming call from Ext.207 to sip:011XXXXXXX@10.0.0.4
    The mistake is that not all the calls are dropped, but i can't understand why!!!
    Any suggestions? thanks.
    Roberto.
  2. Anonymous
    Anonymous Guest
    Is this happening from the same phone or any phone?
    This is only happening for PSTN calls? if so check you FXO port impendance if that is configured correctly.
    Also you call progress settings can play up.
  3. roby78
    Apr 26, 2007
    It happens from any phone, after it happened from one phone, i have tried from another phone and it happened again.
    No voip line configured and internal calls (ext to ext) work. i checked the FXO port impedance and it is configured correctly.
  4. Anonymous
    Anonymous Guest
  5. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    You have dleted ext.207 address in log so I'm guessing it was public IP? I had this '~30 sec.' problem when voip phone was in external network, for phones in same subnet as pbx everything was OK. In my case it was SUTN related issue. Check on STUN settings on your phones and stun port on firewalls.
  6. roby78
    Apr 26, 2007
    Both 3CX server and SPA are on the same Internal IP range. My network configuration is like itfarmer network config. the only difference is that i have a appliance firewall just before the modem. I think the firewall is not involved.
    It isn't a public IP. it's an italian PSTN number.
  7. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Check if IPv6 is enabled on your system. If yes, than turn it off and restart. It should help.
  8. Anonymous
    Anonymous Guest
    Ok,
    Lets assume all is configured correctly but you are dropping after 33 seconds.
    It might not be the SIP registration in you case, so lets tackle it from another angle.
    Set " NAT Keep Alive Enable" to Yes
    Try that.
    It is weird, but we are running out of options, I still think it is a registration issue.
  9. roby78
    Apr 26, 2007
    Hi, sorry for late answer and thank you for all your answers.
    IPv6 is not installed.
    I have tried to set "NAT keep alive enable" to yes, calls still work but every second 3CX server log this:
    11:55:58.152 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: '200'; To: ''; Rline: ''; Contact: ''
    Call hang-up happens very few times.
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    It looks your NAT uses some SIP message to keep alive :) You can just create dummy extension 200 with empty password, and this message will not appear anymore.
