Hi Leejor,
thankyou for your reply i have checked the logs whilst trying to make a call I get the following:
19-Mar-2014 17:25:23.581 [CM506001]: STUN request to resolve SIP external IP
ort mapping is sent to STUN server 198.50.247.220:3478 over Transport 192.168.16.10:5060
19-Mar-2014 17:22:43.107 Leg L:3.1[Extn] is terminated: Cause: BYE from PBX
19-Mar-2014 17:22:43.106 [CM503008]: Call(C:3): Call is terminated
19-Mar-2014 17:22:43.106 Leg L:3.3[EndCall] is terminated: Cause: BYE from 127.0.0.1:40600
19-Mar-2014 17:22:37.204 [CM503007]: Call(C:3): EndCall:EndCall has joined, contact <sip:
[email protected]:40600>
19-Mar-2014 17:22:37.203 [CM503007]: Call(C:3): Extn:202 has joined, contact <sip:
[email protected]:53232>
19-Mar-2014 17:22:37.202 L:3.3[EndCall] has joined to L:3.1[Extn]
19-Mar-2014 17:22:37.004 [CM503025]: Call(C:3): Calling T:EndCall:EndCall@[Dev:sip:
[email protected]:40600;rinstance=3167bc0722c40696] for L:3.1[Extn]
19-Mar-2014 17:22:37.001 L:3.1[Extn] failed to reach Line:10000>>07588107243, reason Forbidden
19-Mar-2014 17:22:37.000 Leg L:3.2[Line:10000>>07588107243] is terminated: Cause: 403 Spoofed From-URI Detected/INVITE from 91.151.2.130:5060
19-Mar-2014 17:22:37.000 Call to T:Line:10000>>07588107243@[Dev:sip:
[email protected]:5060] from L:3.1[Extn]
failed, cause: Cause: 403 Spoofed From-URI Detected/INVITE from 91.151.2.130:5060
19-Mar-2014 17:22:37.000 [CM503003]: Call(C:3): Call to <sip:[email protected]:5060> has failed; Cause: 403 Spoofed From-URI Detected/INVITE from 91.151.2.130:5060
19-Mar-2014 17:22:36.811 [CM503025]: Call(C:3): Calling T:Line:10000>>07588107243@[Dev:sip:[email protected]:5060] for L:3.1[Extn]
19-Mar-2014 17:22:36.639 [CM503027]: Call(C:3): From: Extn:202 ("HG" <sip:[email protected]:5060>) to T:Line:10000>>07588107243@[Dev:sip:[email protected]:5060]
19-Mar-2014 17:22:36.639 [CM503004]: Call(C:3): Route 1: from L:3.1[Extn] to T:Line:10000>>07588107243@[Dev:sip:[email protected]:5060]
19-Mar-2014 17:22:36.639 Line limit check: Current # of calls for line Lc:10000(@Voip-Unlimited[<sip:[email protected]:5060>]) is 0; limit is 20
19-Mar-2014 17:22:36.639 Call(C:3): Call from Extn:202 to 07588107243 matches outbound rule 'Mobiles'
19-Mar-2014 17:22:36.638 [CM503001]: Call(C:3): Incoming call from Extn:202 to <sip:[email protected]:5060>
19-Mar-2014 17:22:15.430 [CM504001]: Endpoint Extn:202: new contact is registered. Contact(s): [sip:[email protected]:53232 / 202]
I'm not really sure what the "failed, cause: Cause: 403 Spoofed From-URI Detected/INVITE from 91.151.2.130:5060"
means exactly or what to look at to fix it, please could you point me in the right direction.
Thanks,
Hamish
