Outbound Calls on 3CXPhone for Android
Discussion in 'Android' started by 9009, Jul 6, 2016.
    Jun 19, 2016
    35
    I have installed 3CXPhone on an Android phone and can NOT make outbound calls on it. It is registered, connected and can receive calls, but can not make calls.
    When I try to make calls I get this: Call failed, Distention not found.
    Here is the Activity log on the 3CX PBX:
    05-Jul-2016 18:20:13.756 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:20:07.182 [Flow] Target endpoint for 3109972200 can not be built!
    05-Jul-2016 18:19:58.396 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:19:43.781 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:19:25.062 [Flow] Target endpoint for 17771234567 can not be built!
    05-Jul-2016 18:19:17.855 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:19:05.148 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:18:36.883 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:18:12.613 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:17:34.826 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.xx because it is on blocked UAs list
    05-Jul-2016 18:17:32.534 [Flow] Target endpoint for 917771234567 can not be built!
    I don't know how to resolve this problem.
    11,277
    360
    I would first suspect the outbound rules (no match), but, it may be an option, for that particular extension, preventing the calls.
    Are you able to make calls to the same number, from other extensions?
    You have X'd out some of the IP from these messages..
    Is that IP, the one you are attempting a call from? If that is the case then you have another issue.
  3. 9009
    Jun 19, 2016
    35
    I don't know what that IP is. I checked the IP of the Android mobile on which I have the 3CXPhone and from which I am trying to make an out bound call, it is different then this IP.
    As soon as I turn on the 3CXPhone on the Android device, without trying to make a call I get this on the Activity Log:
    06-Jul-2016 11:37:15.887 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:36:41.789 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:34:14.017 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:34:00.704 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:32:47.588 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:32:37.656 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:32:13.689 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
    06-Jul-2016 11:32:04.677 PBX has dropped a message with 'User-Agent: VaxSIPUserAgent/3.1' from IP 163.172.194.66 because it is on blocked UAs list
  4. leejor
    11,277
    360
    It may be someone attempting to scan the PBX for vulnerabilities. I have seen logs similar to that. It may not have anything to do with the issue you are having but I though I'd ask since you included the logs.
  5. 9009
    Jun 19, 2016
    35
    I tried it again with the Firewall off, but the same thing happens.
  6. leejor
    11,277
    360
    Are you trying this as a remote extension? If so try a call on the local LAN using Wifi. Do you have other extensions created? Are they able to dial the same number with success?
    The log you provided indicates that you are attempting calls to numbers with several formats/prefixes. What outbound rules have you created?
