Outbound calls on Broadvoice Fast busy call rejected
Discussion in '3CX Phone System - General' started by pkothe, Apr 23, 2007.
  1. pkothe
    Feb 2, 2007
    39
    I am able to get inbound calls no problem, Outbound calls are not working I get "Call (C:A) is rejected: Bad Request" and a fast busy on the phone which I am sure is a standard sip 404 message or something like that. Is there any special setting needed for the provider setup on the headers and invite messages with Broadvoice? I also have a VoIP line with "Voicestep" and it works fine in and out. I am using an outbound rule with a dial 6 for Broadvoice and a Dial 8 for Voicestep and a Dial 9 for my Audiocodes box with 4 PSTN lines. Checked the firewall logs and nothing is being dropped. I did a Wireshark packet capture on the server and I am getting rejected from Broadvice. Any config help on what they may be looking for would be helpful.
    Thanks in advance,
    Paul
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,973
    283
    Hi Paul,
    Broadvoice works fine with 3Cx PHone System. Many of our users use it.
    Ensure that you have followed the manual when configuring it. The next step is to review the server status log, the error will be listed there. Then post the server status log here.
  3. pkothe
    Feb 2, 2007
    39
    More information on the problem
    After extensive testing I have found out some interesting information and I might be on to the possible solution. What I did not tell you in the first post was I already had another VoIP provider called Voicestep in the system and working perfectly, also my Sonicwall firewall firmware has some tricks of its own it can do to sip packets and to the NAT to make it consistent. After playing around with multiple settings on the firewall I found I still could not get both inbound and outbound on both VoIP providers. I finally deleted the Voicestep provider and like magic it works fine both inbound and outbound. Now I need a little help. If you have multiple and different VoIP providers do you need to use unique UDP ports for the registration? At one point, and it was late, I did manage to get 3 of the 4 channels working by changing one of the ports on the Broadvoice screen to 5061 but I did not get both in and out so I was baffled on that one. By the way I think I have 3 sold alerady and you have not even released it yet. I think we are right in the sweet spot for this market.
  4. dekatech
    Feb 13, 2007
    82
    Hi There!
    I use Broadvoice, Junction, and a few other providers for testing all on the same 3CX system. It all works fine. What I did find to be a pain was one time I mistakenly typed the wrong password in for Broadvoice and after 3 registration attempts (it took me longer to relaize it was not registering), Broadvoice locked me out for 30 minutes, I have to remove broadvoice from my 3CX system and add it back after 30 minutes and all worked fine.
    Travis
  5. pkothe
    Feb 2, 2007
    39
    VoIP Providers
    Thanks for the information. I think my problem is how the firewall is configured. One provider likes setting a certain way and the other prover wants it the other way. I am going to mess with it some more later.
  6. Ralph
    Ralph Member
    Jun 28, 2007
    417
    I am having a very similar problem
    I am having a very similar problem.
    I have 2 BroadVoice Lines and a Vitelity line. I can send and receive calls fine on the Vitelity line but I can only receive calls on the Broadvoice lines.
    Where you able to find a solution for this?
    My network layout is as follows:
    Internet -> Firewall -> 3CX Server -> Phones
    The phones and the 3cx server are on the same subnet.
    My server logs from the latest attempt at calling out are as follows:
    10:15:18.179 CallConf::Rejected [CM103005] Call(7) is rejected: Unsupported Media Type
    10:15:18.179 StratInOut::eek:nCancel [CM104008] Call(7): Call from Ext.201 to xxxxxxx terminated; cause: 415 Unsupported Media Type; from IP:147.135.12.221
    10:15:17.829 CallConf::eek:nIncoming [CM103002] Call(7): Incoming call from 201 (Ext.201) to sip:xxxxxxx@xxx.xxx.xxx.xxx
    10:15:03.633 ClientRegs::eek:nSuccess [CM113005] Registration of sip:xxxxxxxxxx@sip.broadvoice.com is successful
    10:15:03.233 ExtLine::Register [CM110004] Send registration for <sip:xxxxxxxxxx@sip.broadvoice.com>
    10:15:03.233 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='BV1'
    10:15:03.223 StunClient::process [CM115002] STUN resolved external IP=xxx.xxx.xxx.xxx:xxxxx by server 80.239.235.209
    I have been beating my head against the wall on this for several days now.
    I have another posting on this in the general forum.
    http://www.3cx.com/forums/viewtopic.php?t=1787
    Any help is greatly appreciated.
  7. pkothe
    Feb 2, 2007
    39
    My Settings that are working
    On the Broadvoice line I have the internal address being used for the contact field for registration and on the Voicestep line I have External Stun selected and they both work fine. I also have one to one NAT setup to my PBX ad I think this has an affect on wether to use External or Internal address option. What firewall type do you have?
  8. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Re: I am having a very similar problem
    It looks that the call is being cancelled by Broadvoice VoIP provider. We have been working with Broadvoice for a very long time and it works perfectly. I will try and replicate this in our test network however I would try to check and see for the codecs used in the phone. The "Unsupported Media Type" is a codec issue. We are checking on this.
  9. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Broadvoice works out of the box. Just tested - broadvoice works fine -
    Have you added any codecs or changed any settings?
    What SIP phone are you using? Have you tried from other phones?
    Can you enable verbose loggings and post the relevant logs here. I would recommend that you restart the PBX services so that there won't be a lot of logs to go through making it more difficult to read and generate the logs exactly after.
  10. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Logs and additional information
    Good morning,
    I have not added any codecs or modified 3CX in any way.
    We are using Polycom Soundpoint IP 501 phones.
    I have attempted to call out with X-Lite and a Grandstream GXP 2000 with the same results. I have also built an identical server and had the same results. The server has its own public IP address and the firewall is wide open to the server.
    I changed logging to verbose and restarted the server. I then attempted to make some calls using one of the Polycom phones. The following are log entries from the 3CXPhoneSystem.trace.log file:
    CSeq: 1 REGISTER
    User-Agent: 3CXPhoneSystem
    Content-Length: 0
    08:24:33.213|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 404 tid=c251e1af9435E338 cseq=REGISTER / 1
    from(tu)
    08:24:33.213|ServerAuthManager.cxx(50)|Trace5|Resip|>>:ServerAuth rejected request SipReq:
    REGISTER xxx.xxx.xxx.xxx:5060 tid=c251e1af9435E338 cseq=REGISTER contact=303@xxx.xxx.xxx.xxx / 1
    from(wire)
    08:24:33.303|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer J tid=c251e1af9435E338
    ms=32000
    08:24:33.303|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4
    xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target
    domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target
    domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0
    ] connectionId=0 ] sent-by=xxx.xxx.xxx.xxx sent-port=0
    08:24:33.303|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 xxx.xxx.xxx.xxx:5060 UDP
    target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified
    connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified
    received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0
    ]SIP/2.0 404 User Not Found
    Via: SIP/2.0/UDP xxx.xxx.xxx.xxx;branch=z9hG4bKc251e1af9435E338
    To: <sip:303@xxx.xxx.xxx.xxx>;tag=7e26236f
    From: "303"<sip:303@xxx.xxx.xxx.xxx>;tag=100ADF1-7E837B44
    Call-ID: 8faaaf5-3349f68b-53830af6@xxx.xxx.xxx.xxx
    CSeq: 1 REGISTER
    Content-Length: 0
    08:24:33.303|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 xxx.xxx.xxx.xxx:5060
    UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified
    08:24:39.822|ClientRegistration.cxx(234)|Trace5|Resip|>>:requesting
    refresh of ClientRegistration sip:XXXXXXXXXX@sip.broadvoice.com
    08:24:39.822|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: REGISTER sip:sip.broadvoice.com SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d87543-1404ec424e6a7123-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:XXXXXXXXXX@xxx.xxx.xxx.xxx:5060;rinstance=401c1f35fb3e4250>
    To: <sip:XXXXXXXXXX@sip.broadvoice.com>
    From: <sip:XXXXXXXXXX@sip.broadvoice.com>;tag=ef3c0a33
    Call-ID: MDU2Nzc3M2I0OGJhNWU2YTAxMTAwNjY2YWFlMjM5MTk.
    CSeq: 24 REGISTER
    Expires: 3600
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Length: 0
    08:24:39.822|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId:
    MDU2Nzc3M2I0OGJhNWU2YTAxMTAwNjY2YWFlMjM5MTk.-ef3c0a33-
    08:24:39.822|DialogUsageManager.cxx(912)|Debug8|Resip|>>:Using outbound proxy:
    sip:XXXXXXXXXX@sip.broadvoice.com:5060;lr -> SipReq: REGISTER sip.broadvoice.com tid=1404ec424e6a7123
    cseq=REGISTER contact=XXXXXXXXXX@xxx.xxx.xxx.xxx:5060 / 24 from(tu)
    08:24:39.912|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer F tid=1404ec424e6a7123 ms=32000
    08:24:39.912|DnsResult.cxx(186)|Debug8|Resip|>>:DnsResult::lookup
    Timer E1 tid=1404ec424e6a7123 ms=500
    08:24:39.912|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up
    source for destination: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com connectionId=0 ] ->
    [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=sip.broadvoice.com connectionId=0 ] sent-by= sent-port=0
    08:24:39.912|TransportSelector.cxx(971)|Debug8|Resip|>>:findTransportBySource([ V4 xxx.xxx.xxx.xxx:0 UDP
    target domain=sip.broadvoice.com connectionId=0 ])
    08:24:39.912|TransportSelector.cxx(1083)|Debug8|Resip|>>:findTransport (any port, any interface) =>
    08:24:39.912|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 147.135.12.221:5060 UDP
    target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified
    domain=sip.broadvoice.com connectionId=0 ]REGISTER sip:sip.broadvoice.com SIP/2.0
    Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-1404ec424e6a7123-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 24 REGISTER
    Expires: 3600
    Content-Length: 0
    08:24:39.912|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 147.135.12.221:5060
    UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target
    08:24:39.972|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 147.135.12.221:5060 UDP target
    ] connectionId=0 ]
    08:24:39.972|DnsResult.cxx(177)|Debug8|Resip|>>:Whitelisting sip.broadvoice.com(1):
    147.135.12.221
    08:24:39.972|dns\RRVip.cxx(129)|Debug8|Resip|>>:updating an existing vip: 147.135.12.221
    with 147.135.12.221
    08:24:39.972|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU:
    DialogUsageManager size=0 SIP/2.0 200 OK
    Via: SIP/2.0/UDP xxx.xxx.xxx.xxx;branch=z9hG4bK-d87543-1404ec424e6a7123-1--d87543-
    Contact: <sip:XXXXXXXXXX@147.135.12.221>
    CSeq: 24 REGISTER
    Expires: 30
    Content-Length: 0
    08:24:39.972|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer K tid=1404ec424e6a7123 ms=5000
    08:24:39.972|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 200 tid=1404ec424e6a7123
    cseq=REGISTER contact=XXXXXXXXXX@147.135.12.221 / 24 from(wire)
    08:24:39.972|DialogUsageManager.cxx(1646)|Debug8|Resip|>>:DialogUsageManager::processResponse: SipResp:
    200 tid=1404ec424e6a7123 cseq=REGISTER contact=XXXXXXXXXX@147.135.12.221 / 24 from(wire)
    08:24:39.972|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId:
    08:24:39.972|ClientRegistration.cxx(327)|Trace5|Resip|>>:Clearing service route ([])
    08:24:39.972|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Registration
    ClientRegistration sip:XXXXXXXXXX@sip.broadvoice.com: duration=25 seq=24
    If you need additional information or different logs please let me know.
    Thanks again,
  11. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Any ideas??
    Just wanted to check in and see if anyone had any ideas about how to fix this??? :?
    Thanks again
  12. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Re: Any ideas??
    PBX doesn't control decisions of other side. If they tell - "Unsupported Media Type", so... media Type is not supported. It seems the only one way to find ideas is to ask support of BroadVoice, why their's software made such decision...
    Thanks,
    Stepan
  13. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Solution Found!!!!
    Good afternoon,
    After many days and untold hours on the phone with a variety of techs from BroadVoice, Firewall manufacturer, phone manufacturer, etc. I finally got to a higher level tech at the firewall manufacturer.
    It turns out that the firewall has a small daemon called "SIP Helper" (you gotta believe this) :roll: and sometimes "SIP Helper" doesn't actually "help" much since it modifies the SIP packets (go figure) :shock: .
    Anyhow, to make a long story short we disabled "SIP Helper" in the Firewall and everything works great now with BroadVoice.
    To bad its not Friday yet, otherwise I could start celebrating immediately :wink:
    Thanks again everyone I appreciate all the effort. BTW I am loving this 3CX software so far :D
    Take care
