outbound calls on GXW4104
Discussion in '3CX Phone System - General' started by nathan, Jan 28, 2008.
  1. nathan
    Jan 1, 2008
    20
    Hi people, hoping someone can help me..
    I have a GXW-4104 and I have followed the setup notes as provided by 3cx.. Inbound calls are OK, they are quiet but at least they get routed to the extension as per the rules.
    I just can't get outbound calls happening...
    20:57:59.087 Call::Terminate [CM503008]: Call(3): Call is terminated
    20:57:59.056 Call::RouteFailed [CM503014]: Call(3): Attempt to reach [sip:32899590@10.0.0.1:5060] failed. Reason: Not Registered
    20:57:59.040 Call::RouteFailed [CM503014]: Call(3): Attempt to reach [sip:32899590@10.0.0.1:5060] failed. Reason: Not Registered
    20:57:59.040 CallCtrl::eek:nSelectRouteReq [CM503015]: Call(3): Target is not registered: PSTNline:32899590 dialed on (AnyLine@GXW4104)
    20:57:59.040 Line::Line [CM303003]: There are no available outbound lines on gateway GXW4104 at this time.
    I am getting the no available lines messages which seems a bit odd as as far as I can tell it is all setup OK. I was trying to get x-lite to connect directly to the gxw4104 but I am not sure whether that can be done. At least doing that I could confirm if the 4104 is working OK.
    I only have one PSTN line so I changed the number of lines to 1 when adding the PSTN lines in 3CX.
    What have I done wrong?
    Nathan
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    According to your log this might be the solution
    Please check the outbound roul, is it configured corectly. You are receving the message since 3cx does not know wjhat to to with the request.
    regards,
  3. nathan
    Jan 1, 2008
    20
    Got it working, just had to disable the "wait for dialtone" option. I am trying to get the settings specific for Australia as I would think that leaving the option enabled would be best....
