Outbound Calls via Salesforce Cases?
Discussion in 'CRM / Helpdesk / App Integration' started by mrpeters, Jun 28, 2017.
  1. mrpeters
    Jun 28, 2017
    5
    Hi all!
    I've been reading through the great document on Salesforce integration provided here but have encountered something that is not covered, but could be really handy.
    Has anyone discovered a way to add a "Call via 3CX" link on a Salesforce "Case" page? The contact phone for the customer is displayed on the case, but the awesome ability to click to call, and the bonus have it log a call activity isn't available here as it is on Accounts, Contacts, and Leads.
    Just curious to see if anyone has found a workaround for this, or if there might be a way to request this feature in a future release.
    Thanks!
    #1 mrpeters, Jun 28, 2017
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    Hello mrpeters
    You can use 3CX click2call for this. https://www.3cx.com/phone-system/click-to-call/
    Also you can create a custom field in cases and specifically you need a Formula(text) field. If you have a Salesforce plugin installed on your 3cx client then you can get the same idea from contacts on the field Call_via_3CX_Phone__c.
    formula examples:
    With link
    -HYPERLINK("tcxcallto:"&Phone,Phone)
    With http request
    -HYPERLINK("http://localhost:47280/SalesforceAPI.aspx?UserAccount="& $User.Username &"&Destination="&MobilePhone&"&ContactId="&Id,"Click here to call this contact with 3CX (MobilePhone)")
    ***You need to have the salesforce plugin installed to make this request
    mrpeters likes this.
  3. mrpeters
    Jun 28, 2017
    5
    Thank you Andreas! That's exactly what I needed to know. Just was looking to confirm that the Call_via_3CX_phone__c API call would work on pages outside of Contacts, Accounts, and Leads.
    Greatly appreciated!
