outbound dialer and predictive dialer
Discussion in 'Call Flow Designer' started by Ravilla, Jan 22, 2018.
  1. Ravilla
    Oct 4, 2017
    64
    I am really confuse how difference between this two features?
    i was thinking that predictive dialer is to call to any number in the list and play the recorded.wav.
    please help to advise.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hello @Ravilla,
    The CFD dialer can work in 2 modes:
    - Power dialer: it will make calls at a steady pace. For example 10 calls per minute.
    - Predictive dialer: it will adapt the call through rate to the number of agents available in a queue to take the call.
    So, if you're going to make calls to play a message, then you can use a power dialer, as you will always have a Digital Receptionist available to play it. The predictive dialer is used when you're sending the calls to a queue, and agents will pick these calls.
    Kind regards.
    Ravilla likes this.
  3. Ravilla
    Oct 4, 2017
    64
    Thanks Ernesto
