Outbound dialer
Discussion in 'Call Flow Designer' started by Goga, Jul 20, 2017.
  1. Goga
    Mar 31, 2017
    16
    I am checking outbound dialer as mention in below link :
    https://www.3cx.com/docs/cfd-creating-outbound-dialer/
    everything is working fine except, when EOF is true, it show result last number it read .
    So the condition mention "GREAT_THAN(LEN(readNumberToCall.Result),0)"
    in flow, not work.
    And system keep calling the the last number it get in result.
    Then i test by put last number as '012' means 3 digit
    and change condition to "GREAT_THAN(LEN(readNumberToCall.Result),4)"
    at .txt I put number 960489935 - it work .
    second number is - 012
    Then also it go to "make call."
    To check further I change condition to "GREAT_THAN(LEN(readNumberToCall.Result),11)"
    then it now allow to go to "make call" as my first number in file is 9 digit.
    I am not sure how it is behaving.
    Any is appreciated.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hello @Goga,
    I think that the problem might be that when the "Read / Write to file" component reads the line, it contains the final CR/LF characters. So, if your number length is 9, you end up with 11 characters.
    In order to avoid this problem, you should use the TRIM function, for example:
    GREAT_THAN(LEN(TRIM(readNumberToCall.Result)),11)
    Can you please check if that makes any difference?
    Kind regards.
  3. Goga
    Mar 31, 2017
    16
    Thanks for your reply.
    After using TRIM it work well. :)
