Outbound Dialer
Discussion in 'Call Flow Designer' started by gustavskii, Aug 22, 2017.
  1. gustavskii
    Jan 26, 2016
    60
    When I set everything up as you have in the example from here:
    https://www.3cx.com/docs/cfd-creating-outbound-dialer/
    Everything is working except it calls even when there are no agents available to take the call
    (for example if an agent logged out of the queue for some reason and all other extensions are on call it dials and puts customer on hold until somebody picks up the call, it builds up amount of calls in queues)
    Did I do something wrong?
    I used the code from the link to check for free extensions
    Code that I used:
    using System;
    using TCX.Configuration;
    namespace OutboundDialerDemo
    public class ExtensionStateHelper
    public bool IsThereAnyFreeExtension()
    return PhoneSystem.Root.GetDNByNumber("117").GetActiveConnections().Length == 0 || PhoneSystem.Root.GetDNByNumber("118").GetActiveConnections().Length == 0 || PhoneSystem.Root.GetDNByNumber("116").GetActiveConnections().Length == 0;
    Is it possible to make the dialer to call only if an agent (agents) is logged in the queue and not currently on call (no matter of queue the call came from)
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
    Hi @gustavskii,
    The sample code provided checks if the extensions are in a call or not. But it doesn't check if the extensions are logged in to queues or not.
    What you need is a bit more complex, please check this forum entry which describes pretty well how to check if extensions are logged in to queues:
    https://www.3cx.com/community/threads/find-amount-of-available-call-queue-agents.49551/
    Also, if you can wait a few weeks, in the next release we'll be providing new components to check if some extension is logged in or not to a queue, so you will be able to do this without any coding... We don't have an ETA for this, but it will be included in the next release, as soon as it becomes available...
    Kind regards.
