Outbound faxing with Windows 2008 doesn't work
Discussion in '3CX Phone System - General' started by mbaltus, Jun 15, 2009.
  1. mbaltus
    Dec 12, 2008
    66
    When trying to fax using Windows 2008 fax server and the 3CX Fax Server plug in, the fax fails.
    This pertains to the latest 3CX v7.1 on a Windows 2008 Standard server.
    According to the log, there is no route to the number, but if I try that number directly from a phone, I can reach it.
    any hints?
    The log of 3CX says (anonimized):
    Code:
    18:47:51.558  [CM503008]: Call(5): Call is terminated
    18:47:51.542  [CM503015]: Call(5): Attempt to reach <sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone> failed. Reason: Not Found
    18:47:51.542  [CM503014]: Call(5): No known route to target: <sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone>
    18:47:51.527  [CM503010]: Making route(s) to <sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone>
    18:47:51.527  [MS210000] C:5.1:Offer received. RTP connection: 192.168.10.5:10002(10003)
    18:47:51.527  Remote SDP is set for legC:5.1
    18:47:51.527  [CM503001]: Call(5): Incoming call from Fax.888 to <sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone>
    18:47:51.527  [CM500002]: Info on incoming INVITE:
      INVITE sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone SIP/2.0
      Via: SIP/2.0/UDP 192.168.10.5:5100;branch=z9hG4bK-64EB-11
      Max-Forwards: 70
      Route: <sip:192.168.10.5:5060;lr>
      Contact: <sip:888@192.168.10.5:5100;user=phone>
      To: <sip:xxxxxxxxxxx@192.168.10.5:5060;user=phone>
      Call-ID: uKx-DmBd8aoNmt8K@192.168.10.5
      CSeq: 16 INVITE
      Allow: INVITE, BYE, ACK, OPTIONS, CANCEL
      Proxy-Authorization: Digest username="888",realm="3CXPhoneSystem",nonce="414d535c00470c3719:b819acf6be5d8405e4f86cf180c8af24",uri="sip:xxxxxxxxxxx@192.168.10.5",response="225181cabdc10c8fd0d50f639b2eb67e",algorithm=MD5,cnonce="37CB",opaque="",nc=00000001
      User-Agent: Netbricks-Sip-T.38IAF/2.01 (PRODUCT ID:5, 05 Jul 2007)
      Content-Length: 0
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    hmm outbound or inbound ?
    are you sure your sda is configured ?
  3. mbaltus
    Dec 12, 2008
    66
    Outbound naturally, since inbound is not supported.
    SDA is?
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    What is destination of your call?
    BTW, What do you mean "inbound is not supported"?
  5. mbaltus
    Dec 12, 2008
    66
    Using the Windows Fax Service. As far as I understoord, receiving faxes using the fax service is not supported.
    The destination is an external fax. I use an application (e.g. Notepad) and fax to the fax driver. To make sure there are no rights issues, I even used the administrator account, but to no avail.
    Calling the number (using one of the regular extensions) is not a problem, so there should not be any routing issues.
  6. archie
    3CX Support
    Aug 18, 2006
    1,299
    FYI, we have our own fax service for inbound faxes.
    Analogue fax machine on ATA? If ATA doesn't support T.38 - it will not work.
  7. mbaltus
    Dec 12, 2008
    66
    What I'm trying to accomplish is using the Windows 2008 fax server to send faxes using 3CX and a Patton 4960 E1 Gateway. Using that I try to fax to an analog fax machine at the other end. Outbound calls to that fax machine or no problem (but rather useless :) ), but faxing gives the mentioned error in the log. For some reason the 3CX Faxserver cannot route correctly, so it seems.
    (btw: I know that inbound faxing is supported on 3CX, although having some issues with that as well. But that's stuff for a different topic).
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    Set FAXDIRECTSDP = 1 in custom parameters.
  9. mbaltus
    Dec 12, 2008
    66
    I'll try what that does tonight.
    I assume I need to restart services?
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, this setting has immediate effect.
