Outbound & Inbound calling
Discussion in '3CX Phone System - General' started by miloabc, Dec 5, 2006.
  1. miloabc
    Nov 20, 2006
    13
    I recently installed the 3CX phone system, i think it is a great program!
    I configured it with my voip provider, and i could make and recieve calls successfully.
    But now i cant do any of the above! When i make an outbound call, it just rings out. The following is what is in the server log: (I have replaced the last 4 digits of the number with ****).
    09:15:36.312 Terminated c11 "252"<sip:252@192.168.0.5> <sip:09341****@192.168.0.5> Call ended
    09:15:35.359 Calling c11 "252"<sip:252@192.168.0.5> <sip:09341****@192.168.0.5> Send INVITE to [#086262**** @iiNet]
    09:15:35.078 Routed c11 "252"<sip:252@192.168.0.5> <sip:09341****@192.168.0.5> From: Ext:252; To: [#086262**** @iiNet]
    09:15:35.078 CallConf::findDestination: Found destination [#086262**** @iiNet] for caller Ext:252
    I do press zero before making an outbound call.
    And the funny thing is, It says that my voip provider is registered, no errors at all.
    Thanks in advance!
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It looks like you've run out of credits at your voip provider. Please, check it out. We had similar behavior when we'd run out of credits. Otherwise, try to configure some softphone client to reach your provider directly from it, and than try to make a call. If it works, but 3CX still not works with the same settings - please, contact 3CXSupport for next instructions.
    Best regards,
