Outbound lines
Discussion in '3CX Phone System - General' started by mrLunkwill, Oct 15, 2006.
  1. mrLunkwill
    Oct 15, 2006
    7
    I cant find a way to set what internal phone should have what external number for outbound?
    i.e I have a Extension called 101 and ten VoIP called 10000-10009 - its no problem to set if someone dials to the phonenumber connected to 10001 to connect to extension 101. But when extension 101 dials out I want it to use 10001 - how do i do that (see Axon DialingPlans)
    (all ten lines is one same operator - and no I dant want diffrent numbers to access outside line for diffrent extensions)
    //mrLunkwill
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,990
    304
    Use dialing rules
    To do this you would need to create outbound dialing rules. You could create a prefix for each VOIP provider. Then dial the prefix plus the number to use a particular VOIP provider. The latest manual (updated friday 13th October) has examples and a description how to do that.
