- Joined
- Apr 6, 2011
- Messages
- 92
- Reaction score
- 4
Is there any documentation on what the various values *mean* for this config area?
I'm trying to get outbound CLI working and I'm doing a "spot the difference" between two 3CX setups, one of which is working and one is not, they have the same Sip Trunk provider, so I should be able to get there...
The ONLY difference I can see is in the "Remote Party ID - Host Part", where the working PBX is set to "DevHostPort" and the non-working one (well it works but it always presents the *default* line CLI not the DDI set in the extension) is set to "GwHostPort".
But in all the places where the working PBX has a value of "Outbound Caller Id taken from Extension", the non-working one does too!
(It doesn't help that this table view within the dialog doesn't present in the same order on both machines, nor does it appear to be sortable by clicking on the column header as one would normally expect in Windows. )
